Go to Post Now its up to us to show that what we shout from the high places is also true down on the street. - KenWittlief [more]
Thread Tools Rating: Thread Rating: 4 votes, 5.00 average. Display Modes
  #31   Spotlight this post!
Unread 14-11-2015, 13:16
Scott Kozutsky's Avatar
Scott Kozutsky Scott Kozutsky is offline
FRC #0865
Rookie Year: 2010
Scott Kozutsky will become famous soon enough
Re: Designing a "belt + roller" conveyor for balls
Originally Posted by Jared Russell View Post
When 341 made extensive use of polyurethane flat belting in 2012 (and 2013), we used exclusively 1.25" OD, 1.12" ID aluminum round tubing from Online Metals for our rollers. 10 seconds on the lathe (or a minute with a deburring tool) and it is a great fit for a hub or 1.125" OD bearing.
In 2014 we used the polycarb tube for our rollers and it definitely suffered from a lack of rigidity. The aluminum upgrade is definitely something I would recommend. Our tubes were around 2ft+ long.
2010-2012 FRC 865 Warp7 Student, Mechanical
2013 FRC 1310 RUNNYMEDE ROBOTICS Student, Mechanical, Design
2014 FRC 865 Warp7 Student, Mechanical, Design
2015 FRC 865 Warp7 Alumni, Mechanical Mentor
  #32   Spotlight this post!
Unread 15-11-2015, 17:16
Monochron's Avatar
Monochron Monochron is offline
Engineering Mentor
AKA: Brian O'Sullivan
FRC #4561 (TerrorBytes)
Monochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond repute
Thanks for all the great feedback everyone, the team working on the beltway for our shooter got a lot of use out of the resources you guys provided.
We currently have the plates that make up the shooter assembly CADed and will sending them out for manufacturing on Monday. If people wouldn't mind giving the design and especially the drawing a look over we would really appreciate it.
Shooter Plate
Shooter Plate Drawing
Feedback I would particularly like include:
  • We're going with a 1/4" thick plate, is that appropriate for this application?
  • Is the pocketing too agresive? ie. are 1/4" aluminum struts strong enough?
  • Is the Drawing too hectic? It looks like I have a lot of dimentions crammed in there...
  • Also any overal design comments you have are welcome
  #33   Spotlight this post!
Unread 16-12-2015, 00:49
jman4747's Avatar
jman4747 jman4747 is offline
Just building robots
AKA: Josh
FRC #4080 (Team Reboot)
Team Role: CAD
Rookie Year: 2011
jman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond repute
Has anyone else used hollow core round belt with the barbed connector? Example: http://www.mcmaster.com/#6567k57/=109btha (belt) http://www.mcmaster.com/#6567k22/=109bt5d (connector)
Alumni, CAD Designer, machinist, and Mentor: FRC Team #4080
Mentor: Rookie FTC Team "EVE" #10458, FRC Team "Drewbotics" #5812
#banthebag
#RIBMEATS
#1620
  #34   Spotlight this post!
Unread 16-12-2015, 08:23
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Rookie Year: 2013
We used this type of belt for our rookie 2012 Rebound Rumble robot to pick the basketballs off the floor and raise them to the cup which would lift them to the shooter. It was probably the most reliable system on the robot. I was not as involved that year, so I don't know why, but the belt was taped together rather than just held with the barbed connector. I suspect that it was because we were running it around about 1" diameter rollers (larger is recommended).
  #35   Spotlight this post!
Unread 16-12-2015, 08:38
jman4747's Avatar
AKA: Josh
Team Role: CAD
Rookie Year: 2011
That's my exact situation. Last time we used them was on our 2012 rookie bot and they were also on < 2" diameter rollers and taped. I was wondering if anyone else had because like you I wasn't very involved with the lift and want to make sure we didn't just get lucky with it.
#banthebag
#RIBMEATS
#1620
  #36   Spotlight this post!
Unread 16-12-2015, 08:49
Chris is me's Avatar
AKA: Pinecone
Back in high school (seven years ago!!! ) my team used these in 2009 for a ball conveyor, just using the barbed connectors to join them, around ~2" rollers. Worked well, I don't think they ever pulled themselves apart. The belts may have stretched a bit over time since they are hollow and relatively thin, so have some extra barbs so you can shorten longer runs over time. Welded poly-cord is probably more robust but this was good enough for 2009.
I personally prefer the orange flat stuff since it's a bit tackier and has nice self-centering properties.
  #37   Spotlight this post!
Unread 16-12-2015, 09:14
Ari423's Avatar
Ari423 Ari423 is offline
LabVIEW aficionado and robot addict
AKA: The guy with the yellow hat
FRC #5987 (Galaxia)
Rookie Year: 2012
Ari423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant future
My team also used them for our intake in 2012 and we did use the barbs. When we first cut the urethrane, the barbed connectors constantly popped out. After a few days of sitting and stretching they would be fine until the urethrane would stretch too much, we would have to re-cut it, and the process would start over again. Also, the barbed connectors are a pain to take out. That being said, they worked pretty well for our intake, and I would use them again if the need arises.
2017-present: Mentor FRC 5987
2017-present: CSA for FIRST in Israel
2012-2016: Member FRC 423
2013: Programmer
2014: Head Programmer, Wiring
2015: Head Programmer, Wiring
2016: Captain, Head Programmer, Wiring, Manipulator, Chassis, CAD, Business, Outreach (basically everything)
  #38   Spotlight this post!
Unread 16-12-2015, 19:08
mott's Avatar
mott mott is offline
AKA: Mike Ott
FRC #1619 (Up-A-Creek Robotics)
mott is on a distinguished road
Other than the added complexity of machining the bore of the tube ends, would it be worth using the 1.25" OD polycarb tubing with the 1" ID and then machining the bore of the tube ends to accept the 1.125" bearing and hub? Besides being significantly stiffer, this would also allow you to intentionally undersize the bore to get the amount of "press fit" you might want for the inserts.
