Originally Posted by jkelleyrtp
In this situation, your forward or direct traction would be similar to that of a standard four wheel drive, but laterally against the faces of the wheels, your friction force would be about half. It also changes your center of rotation, but making a 6wd with two front omnis would be a good compromise: wide wheel base for 4 traction wheels and the stability of a 6wd.
We used this setup in
2013 and loved it. In
2014 we switched to 8wd tank, with no drop but the far front and far back wheels being omnis. We hated it. Partially because our gear ratios were wrong and we had misaligned chains, but it didn't work for us -- we tripped breakers, popped chains, and still couldn't push very well. This year we went back to the 2013 setup (back traction, front omni) and again loved it. The problem is finding (non-custom) gearboxes to direct drive wheels that bolt on easily to 1x2" aluminum frames. Back in 2012 I was on a team that build a wide 4wd traction setup, which worked very well for bridge balancing, but "hopped" when it tried to turn and drive at the same time. Being wide made the drive better than 4wd long, but it still wasn't great.
We're getting ready to build a "Texas Tube" drivetrain -- 6wd drop center, chain in tube -- setup in the coming weeks, and may well run that in 2016, pending the game. The 6wd benefit over the 4wd traction/omni setup is traction, especially in turning situations with defense. We avoided most defense in 2013 (and our driver was insane -- he did spin-moves around other robots, it was crazy), so it wasn't a problem, but it can be.
I wouldn't recommend building a drivetrain for the first time ever during build season if you can help it. You never know that kind of problem might pop up, or how it will perform for you until you've tried, and it's far harder to rebuild a chassis and drivetrain after the robot it complete than during the offseason.
The Hitchhikers
Team2059.org
2011 NC Regional: Rookie All Star Highest Seeded Rookie, 3459
2012 SCRIW: Champions, 2059
2013 NC Regional: Finalists, 2059 (Thank you 1539 and 2655!)
2014 NC Regional: Industrial Design Award, 2059
2014 THOR: Finalist, 2059
2015 Palmetto Regional: Gracious Professionalism Award, Finalists (Thank you 1533 and 1261!), 2059
2015 NC Regional: Industrial Safety Award, Engineering Inspiration Award, Winner (Thank you 1225 and 900!), 2059
