Re: CAD mount for a bearing to be used as a wheel.
What direction is the load being borne? Is this module being compressed vertically by the load, or ?? (most likely if it's a drive module)
By roll inside the bar, do you mean for it to rotate around the axis through the center of the long axis of the tang (upside-down T- piece) or something else?
