Go to Post Teams that TRY to win and TRY to do their best end up having students that learn more, learn the value of hard work, and are inspired by the process. - Chris Hibner [more]
Unread 14-11-2015, 20:17
FRC Team CC FRC Team CC is offline
FRC #6560 (Charging Champions)
Rookie Year: 2012
FRC Team CC is an unknown quantity at this point
[FTC]: Servo Wire Connection
Chief Delphi,
We are the Charging Champions, team 8660 from SoCal. We had a question regarding the unreliability of servo connections. Last year, since one of our servos required an extension, we bought some cables from TETRIX (http://www.tetrixrobotics.com/Servo_Extension). However, they came apart very easily, costing us several matches. This year, we would like to avoid that problem.
Is there a different kind of connector (like how Anderson Powerpoles replace Tamiya connectors) that would solve this problem? Thanks in advance.
Sincerely,
The Charging Champions
FTC Team #8660
Facebook Page: https://www.facebook.com/chargingchampions
Follow us on Twitter: @FtcTeamCC
Google Plus: https://plus.google.com/112552147224383900922/posts
Youtube channel: https://www.youtube.com/channel/UCop...G3zsvQKCXF4ESQ
Blog: http://chargingchampionsblog.blogspot.com/
Unread 15-11-2015, 15:21
maths222 maths222 is offline
FTC FTA
AKA: Jacob Burroughs
Rookie Year: 2010
maths222 is a splendid one to beholdmaths222 is a splendid one to beholdmaths222 is a splendid one to beholdmaths222 is a splendid one to beholdmaths222 is a splendid one to beholdmaths222 is a splendid one to beholdmaths222 is a splendid one to behold
Re: [FTC]: Servo Wire Connection
There aren't really alternate connectors. That said, I strongly zip-tying all extension cable connections and/or wrapping in electrical tape. Use the really thin zip ties, and thread them in between the wires on both sides, and you will have a connector that does not fall apart. Also, see the PWM cables at AndyMark if you want other lengths (http://www.andymark.com/product-p/am-0695.htm)
--Jacob
Illinois FTC FTA
Unread 15-11-2015, 15:45
Rookie Year: 2012
Thanks for the tips.
FTC Team #8660
