Go to Post Al Gore invented the internet...right? :p - coastertux [more]
Unread 15-11-2015, 10:58
notmattlythgoe's Avatar
notmattlythgoe notmattlythgoe is offline
Flywheel Police
AKA: Matthew Lythgoe
FRC #2363 (Triple Helix)
notmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond repute
Java Conditional Command
Here is an idea I had recently for conditional wait commands. Thoughts?
With just a couple of static imports you could be writing CommandGroups that look like this.
Code:
package org.usfirst.frc.team2363.robot.commands;
import static org.usfirst.frc.team2363.robot.Robot.drivetrain;
import static org.usfirst.frc.team2363.robot.commands.ConditionalWaitCommand.Operation.*;
import static org.usfirst.frc.team2363.robot.commands.ConditionalWaitCommand.*;
import edu.wpi.first.wpilibj.command.CommandGroup;
public class DriveToLine extends CommandGroup {
    public  DriveToLine() {
    	addSequential(new DriveCommand(0.5));
        addSequential(waitUntil(drivetrain.getDistance(), GREATER_THAN, 50));
        addSequential(new DriveCommand(0));
Code:
import edu.wpi.first.wpilibj.command.Command;
public class ConditionalWaitCommand extends Command {
	public enum Operation {
		LESS_THAN, LESS_THAN_EQUAL, EQUAL, GREATER_THAN_EQUAL, GREATER_THAN
	public interface IProvidesValue {
		double getValue();
	public static ConditionalWaitCommand waitUntil(IProvidesValue operand1, Operation operation, double operand2) {
		return new ConditionalWaitCommand(operand1, operation, operand2, true);
	public static ConditionalWaitCommand waitWhile(IProvidesValue operand1, Operation operation, double operand2) {
		return new ConditionalWaitCommand(operand1, operation, operand2, false);
	private IProvidesValue operand1;
	private Operation operation;
	private double operand2;
	private boolean isUntil;
    private ConditionalWaitCommand(IProvidesValue operand1, Operation operation, double operand2, boolean isUntil) {
        this.operand1 = operand1;
        this.operation = operation;
        this.operand2 = operand2;
        this.isUntil = isUntil;
    @Override
	protected void initialize() { }
	@Override
	protected void execute() { }
    protected boolean isFinished() {
    	switch (operation) {
			case EQUAL:
				if (operand1.getValue() == operand2) {
					return isUntil;
			case GREATER_THAN:
				if (operand1.getValue() > operand2) {
					return isUntil;
			case GREATER_THAN_EQUAL:
				if (operand1.getValue() >= operand2) {
					return isUntil;
			case LESS_THAN:
				if (operand1.getValue() < operand2) {
					return isUntil;
			case LESS_THAN_EQUAL:
				if (operand1.getValue() <= operand2) {
					return isUntil;
        return !isUntil;
	@Override
	protected void end() { }
	@Override
	protected void interrupted() { }
Code:
package org.usfirst.frc.team2363.robot.subsystems;
import org.usfirst.frc.team2363.robot.commands.ConditionalWaitCommand.IProvidesValue;
import edu.wpi.first.wpilibj.Encoder;
import edu.wpi.first.wpilibj.command.Subsystem;
public class Drivetrain extends Subsystem {
    private Distance distance;
    private Encoder encoder = new Encoder(1, 2);
    public void initDefaultCommand() { }
    public IProvidesValue getDistance() {
    	if (distance == null) {
    		distance = new Distance();
    	return distance;
    private class Distance implements IProvidesValue {
		@Override
		public double getValue() {
			return encoder.getDistance();
