Go to Post I too can find a method with correlation bias by applying a pattern to most datasets! - BrennanB [more]
Unread 17-11-2015, 11:02
MattRain MattRain is offline
AZ FTC AF, FTC #2844 and FTC #8640
FRC #1492 (Team Caution)
Team Role: RoboCoach
MattRain has a brilliant futureMattRain has a brilliant futureMattRain has a brilliant futureMattRain has a brilliant futureMattRain has a brilliant futureMattRain has a brilliant futureMattRain has a brilliant futureMattRain has a brilliant futureMattRain has a brilliant futureMattRain has a brilliant futureMattRain has a brilliant future
Delta Drill Press Belt? Aftermarket Part?
Does anyone know of a belt that can work with an older Delta Drill Press? Model Number 11-990 TYPE 1.
http://www.ereplacementparts.com/vbelt-p-83036.html
http://www.mikestools.com/1343782-Delta-Belt.aspx
Belt is showing as Obsolete.
The belt snapped last night in the middle of our FTC season. The belt has "K 32.5" printed onto it. Anyone else on these forums have this drill press?
2015 FTC WORLD CHAMPIONS
www.valleyx2844.com
Twitters: Valley X & Trojan Robotics & Team Caution
(World Championship Counter: 5)
*All my posts reflect my opinion, not my teams.*
"I WANT CHEETOS!" - Bad Lip Reading 2016 <-- ME
Unread 17-11-2015, 11:06
Mark McLeod's Avatar
Mark McLeod Mark McLeod is online now
Just Itinerant
AKA: Hey dad...Father...MARK
FRC #0358 (Robotic Eagles)
Re: Delta Drill Press Belt? Aftermarket Part?
Think this might work?
http://www.amazon.com/Urethane-Repla.../dp/B00UW4VUUI
or this
http://stores.renovoparts.com/1343782-v-belt/
Unread 17-11-2015, 11:11
I saw that, but its a completely different design. The belt that snapped was a V shaped black belt, as were that one has teeth and clear. Im not sure if it would act the same way.
If I can find a belt similar to size, I can move the Drill Press Motor slightly to make up for the added length.
EDIT: The Second link may be it. I will check again on the press at lunch. Thank you
www.valleyx2844.com
Unread 17-11-2015, 11:14
MrForbes's Avatar
MrForbes MrForbes is online now
AKA: Jim
FRC #1726 (N.E.R.D.S.)
you might also consider taking the broken belt to a place that sells lots of them, and see if they have a match in stock.
http://www.bbcarizona.com/
for example. You didn't say how wide it is, so I dont know if there might be other sources.
The urethane belt should be a suitable replacement, if it's the same width and length. The material and "teeth" dont really matter much.
Unread 17-11-2015, 11:22
I don't know the size off the top of my head, but its currently sitting in the car. That place is just a few minutes from my office, I will head over there today or tomorrow to see if they have anything that would work. THANKS!
www.valleyx2844.com
Unread 17-11-2015, 12:14
Mr V's Avatar
Mr V Mr V is offline
FIRST Senior Mentor Washington
FRC #5588 (Reign)
Team Role: Coach
Mr V has a reputation beyond reputeMr V has a reputation beyond reputeMr V has a reputation beyond reputeMr V has a reputation beyond reputeMr V has a reputation beyond reputeMr V has a reputation beyond reputeMr V has a reputation beyond reputeMr V has a reputation beyond reputeMr V has a reputation beyond reputeMr V has a reputation beyond reputeMr V has a reputation beyond repute
Do you have an old school hardware store, power equipment store, or NAPA near by? If so take the broken belt in and they'll match it up with a suitable belt. It has a nominal OD of 33" and a nominal width of 5/8". 32.5" is the diameter of the center of the working surface. You want a power transmission belt like used in lawn equipment, washing machines, ect but an automotive belt will work in a pinch and get you back in business today.
The belts with the "teeth" are fully compatible, in theory they last longer by running cooler and run quieter, at least if the teeth have random spacing.
All statements made on Chief Delphi by me are my own opinions and are not official FIRST rulings or opinions and should not be construed as such.
https://www.facebook.com/pages/Team-...77508782410839
Unread 17-11-2015, 12:25
MrForbes's Avatar
AKA: Jim
like this?
http://www.oreillyauto.com/site/c/de...325/03305.oap?
Unread 17-11-2015, 13:52
Mr V's Avatar
FRC #5588 (Reign)
Team Role: Coach
No actually I meant a belt like this http://www.oreillyauto.com/site/c/de...&keyword=5l330 since it is a wrapped industrial belt. The automotive one will work in a pinch but the profile is slightly different between the industrial and automotive belts.
Unread 17-11-2015, 14:07
I picked up the one that exact one at lunch. I will try it out after work.
Thank you guys.
www.valleyx2844.com
Unread 17-11-2015, 14:17
Mr_I's Avatar
Mr_I Mr_I is offline
AKA: Tom Indelicato, 811 Moderator, Mentor, Parent, ...
FRC #0811 (Cardinals)
Team Role: Teacher
Mr_I has a brilliant futureMr_I has a brilliant futureMr_I has a brilliant futureMr_I has a brilliant futureMr_I has a brilliant futureMr_I has a brilliant futureMr_I has a brilliant futureMr_I has a brilliant futureMr_I has a brilliant futureMr_I has a brilliant futureMr_I has a brilliant future
You probably found a replacement by now, but this product might be useful for those who need a replacement. It's designed to reduce vibration on tools such as table saws, drill presses, and other power tools. (I use it on my table saw, and it works!) The best part is you get to make it as long as you need.
http://www.rockler.com/1-2-power-twist-plus-link-v-belt
"It's NOT Just A Robot Thing!"
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Team Role: Teacher
Ebay, take your pick:
http://www.ebay.com/itm/NEW-Replacem...AOSw4SlV7wf d
http://www.ebay.com/itm/NEW-Replacem...AOSw9mFWJwh Z
Unread 17-11-2015, 12:34
karlonpc karlonpc is offline
FRC #2587 (DiscoBots)
Rookie Year: 2012
karlonpc is an unknown quantity at this point
Buy a link belt and just make it the correct size, if the original belt was a vee belt
Unread 17-11-2015, 12:44
Thank you! I have a loaner drill press for the time being, until we got a new belt.
That's the shape of the belt, yep.
www.valleyx2844.com
Unread 17-11-2015, 12:49
MrForbes's Avatar
AKA: Jim
I meant that size, too.
