Go to Post I'm sure you can come up with something, with a bit of warped thought! ... and if not, warped thinking is what your team's Engineers are for! :) - kmcclary [more]
Unread 18-11-2015, 20:24
josephno1's Avatar
josephno1 josephno1 is offline
FRC #3647
Rookie Year: 2015
josephno1 is an unknown quantity at this point
PID Controller help
So I followed the example on here.
http://wpilib.screenstepslive.com/s/...rs-pid-control
So this is what I got so far.
The PID Controller is plugged in on PWM port 0 and AnalogInput 2
How do I call this in the Robot.java and what do I do next?
I am using IterativeRobot
Code:
import edu.wpi.first.wpilibj.command.PIDSubsystem;
import edu.wpi.first.wpilibj.livewindow.LiveWindow;
import edu.wpi.first.wpilibj.Talon;
import edu.wpi.first.wpilibj.SpeedController;
import edu.wpi.first.wpilibj.AnalogInput;
import edu.wpi.first.wpilibj.*;
public class PIDWheel extends PIDSubsystem {
	SpeedController motor = new Talon(0);
	AnalogInput pot = new AnalogInput(2);
    // Initialize your subsystem here
    public PIDWheel() {
    	super("Wheel", 1.0, 0.0, 0.0);
    	setAbsoluteTolerance(0.2);
    	getPIDController().setContinuous(false);
    	LiveWindow.addActuator("Wheel", "PIDSubsystem Controller", getPIDController());
        // Use these to get going:
        // setSetpoint() -  Sets where the PID controller should move the system
        //                  to
        // enable() - Enables the PID controller.
    public void initDefaultCommand() {
        // Set the default command for a subsystem here.
        //setDefaultCommand(new MySpecialCommand());
    protected double returnPIDInput() {
        // Return your input value for the PID loop
        // e.g. a sensor, like a potentiometer:
        // yourPot.getAverageVoltage() / kYourMaxVoltage;
    	return pot.getAverageVoltage();
    protected void usePIDOutput(double output) {
    	motor.pidWrite(output);
        // Use output to drive your system, like a motor
        // e.g. yourMotor.set(output);
