Go to Post This our big chance to spread the word and change the culture, let's not waste it. So in the words of one Leroy Jenkins, "Time's up, let's do this." - Frenchie461 [more]
Unread 19-11-2015, 19:06
Bernstern Bernstern is offline
FRC #2141 (Spartonics)
Rookie Year: 2015
Bernstern is an unknown quantity at this point
Newbie How to control a spike
In our code for a tshirt cannon (Im a freshman and get all the bad jobs) I was tasked with making the relay (Spike) shoot the actual cannon. I have no idea. I tinkered and set this up like so:
Subsystem
package org.usfirst.frc.team2141.robot.subsystems;
import org.usfirst.frc.team2141.robot.RobotMap;
import org.usfirst.frc.team2141.robot.commands.CannonCont rol;
import edu.wpi.first.wpilibj.Relay;
import edu.wpi.first.wpilibj.Relay.Direction;
import edu.wpi.first.wpilibj.Relay.Value;
import edu.wpi.first.wpilibj.command.Subsystem;
public class Cannon extends Subsystem {
Relay cannonFire;
public Cannon() {
cannonFire = new Relay(RobotMap.CANNON_CHANNEL);
public void cannonFire() {
cannonFire.set(Value.kOn);
// Put methods for controlling this subsystem
// here. Call these from Commands.
public void initDefaultCommand() {
// Set the default command for a subsystem here.
//setDefaultCommand(new MySpecialCommand());
setDefaultCommand(new CannonControl());
Command
package org.usfirst.frc.team2141.robot.commands;
import org.usfirst.frc.team2141.robot.OI;
import org.usfirst.frc.team2141.robot.Robot;
import edu.wpi.first.wpilibj.command.Command;
public class CannonControl extends Command {
public CannonControl() {
// Use requires() here to declare subsystem dependencies
// eg. requires(chassis);
requires(Robot.cannon);
// Called just before this Command runs the first time
protected void initialize() {
// Called repeatedly when this Command is scheduled to run
protected void execute() {
if (Robot.oi.getButtons()[5].get()) {
Robot.cannon.cannonFire();
// Make this return true when this Command no longer needs to run execute()
protected boolean isFinished() {
return false;
// Called once after isFinished returns true
protected void end() {
// Called when another command which requires one or more of the same
// subsystems is scheduled to run
protected void interrupted() {
What am I doing wrong?
