Go to Post If you want to prove your worth, prove it by creation, not destruction. - DanL [more]
Unread 11-23-2015, 09:06 PM
stu54 stu54 is offline
None #2458
stu54 is an unknown quantity at this point
Netbeans cRIO and newer Java
I am using our old cRIO for some off-season development. So this means I am also using Netbeans and the 2014 FRC plug-ins. I would like to use some newer Java features like enum but it looks like the FRC plug-ins are tied to a much older version of the JDK.
Is it possible to use a newer JDK with the 2014 WPILib/FRC plug-ins? I could not figure out where in the Ant build scripts the java compiler path is specified but maybe I don't understand how code is compiled for the cRIO.
Thanks!
Unread 11-24-2015, 09:02 AM
Ben Wolsieffer Ben Wolsieffer is offline
Dartmouth 2020
AKA: lopsided98
FRC #2084 (Robots by the C)
Rookie Year: 2011
Ben Wolsieffer has much to be proud ofBen Wolsieffer has much to be proud ofBen Wolsieffer has much to be proud ofBen Wolsieffer has much to be proud ofBen Wolsieffer has much to be proud ofBen Wolsieffer has much to be proud ofBen Wolsieffer has much to be proud ofBen Wolsieffer has much to be proud of
Re: Netbeans cRIO and newer Java
You cannot use a newer JVM on the cRIO, because it does not use the standard Oracle JVM, like the roboRIO. The cRIO uses the Squawk VM, which only implements Java 2 features.
2016 North Shore District - Semifinalists and Excellence in Engineering Award
2015 Northeastern University District - Semifinalists and Creativity Award
2014 Granite State District - Semifinalists and Innovation in Control Award
2012 Boston Regional - Finalists
Unread 11-24-2015, 02:28 PM
None #2458
Thanks for the reply. I am using the cRIO for non-competition use so I wonder if the Squawk VM can be recompiled to use more up-to-date Java features. I saw a project for it on Java.net but I don't know if that could be updated or recompiled for newer features.
