Wanna hang together?
  #16   Spotlight this post!
Unread 11-12-2015, 22:31
End-Game's Avatar
End-Game End-Game is offline
AKA: Skipper
FRC #1339 (Angelbots)
Rookie Year: 2012
End-Game is a jewel in the roughEnd-Game is a jewel in the roughEnd-Game is a jewel in the roughEnd-Game is a jewel in the rough
Re: "Waffle" East Angelbots 1339 Offseason Project
Another update on our progress. We are in the midst of wiring and plumbing the Robot, and should have the structure, with the exception of a few parts, done by the end of tomorrow.
http://imgur.com/a/634HB
We Don't Make Sense, We Make Robots.
If you can't find the time to do it Right, how will you find time to do it Over?
Mecanum, a drive system so graciously professional that it lets other teams drive your robot.
  #17   Spotlight this post!
Unread 11-12-2015, 23:54
jkelleyrtp's Avatar
jkelleyrtp jkelleyrtp is offline
Let's just build a robot
AKA: Jon Kelley
FRC #5511 (Cortechs Robotics)
Team Role: Leadership
Rookie Year: 2014
jkelleyrtp has much to be proud ofjkelleyrtp has much to be proud ofjkelleyrtp has much to be proud ofjkelleyrtp has much to be proud ofjkelleyrtp has much to be proud ofjkelleyrtp has much to be proud ofjkelleyrtp has much to be proud ofjkelleyrtp has much to be proud ofjkelleyrtp has much to be proud of
Originally Posted by BBray_T1296 View Post
tl;dr Churro tube has an exceptionally poor torsional stiffness per unit weight, for weight savings use a hex axle with a hole drilled in it instead
Does that mean ThunderHex by Vex is the best COTS option for weight savings and torque distribution?
By your numbers:
ThunderHex is 1/2" in size
.2" central bore
15% less weight by cross sectional area. ((.5^2)pi-(.2^2)pi))/((.5^2)pi)
The central .2" carries less than 2% of the total load?
Cortechs Robotics 2014-Present
Mechanical, CAD
  #18   Spotlight this post!
Unread 12-12-2015, 00:16
s_forbes's Avatar
s_forbes s_forbes is offline
anonymous internet person
FRC #0842 (Falcon Robotics)
s_forbes has a reputation beyond reputes_forbes has a reputation beyond reputes_forbes has a reputation beyond reputes_forbes has a reputation beyond reputes_forbes has a reputation beyond reputes_forbes has a reputation beyond reputes_forbes has a reputation beyond reputes_forbes has a reputation beyond reputes_forbes has a reputation beyond reputes_forbes has a reputation beyond reputes_forbes has a reputation beyond repute
I would assume that to be the case, but it would be interesting to see what torque is required to make a ThunderHex shaft fail vs a standard Vex Hex shaft... the rounded corners on the ThunderHex and bored out center might let it round off inside of a hub with enough torque. Or not... it sounds like a neat test.
Keep in mind the weight savings of the hole in the shaft are pretty minuscule, something you might be able to offset with several strategically placed helium balloons.
  #19   Spotlight this post!
Unread 12-12-2015, 22:08
End-Game's Avatar
AKA: Skipper
Rookie Year: 2012
An image album of the completed structure, with most of the wiring and pneumatics finished.
This also shows our strategy for acquiring the flag.
http://imgur.com/a/4Uoq6
  #20   Spotlight this post!
Unread 16-12-2015, 23:46
Sl3dman's Avatar
Sl3dman Sl3dman is offline
Rookie Year: 2015
Sl3dman is an unknown quantity at this point
Waffle bot update
  #21   Spotlight this post!
Unread 17-12-2015, 03:49
BBray_T1296's Avatar
BBray_T1296 BBray_T1296 is offline
I am Dave! Yognaut
AKA: Brian Bray
FRC #1296 (Full Metal Jackets)
Rookie Year: 2010
BBray_T1296 has a reputation beyond reputeBBray_T1296 has a reputation beyond reputeBBray_T1296 has a reputation beyond reputeBBray_T1296 has a reputation beyond reputeBBray_T1296 has a reputation beyond reputeBBray_T1296 has a reputation beyond reputeBBray_T1296 has a reputation beyond reputeBBray_T1296 has a reputation beyond reputeBBray_T1296 has a reputation beyond reputeBBray_T1296 has a reputation beyond reputeBBray_T1296 has a reputation beyond repute
By your numbers:
.2" central bore
Those should be powers of 4, but the result is correct. A hollow round shaft with those parameters is just 2.56% less torsionally rigid than a solid shaft.
The existence of the hexagon-generating surface features complicates things if you care for precise numbers, but from this simplified situation, ThunderHex is the most efficient choice.
What is happening on a molecular level is, the atomic bonds on the outside edges of the shaft are being stretched in plane shear more than the atoms on the inside of the shaft for the same rotational displacement. In addition, there are more atoms on the outside edge than the inside near the center that are being stretched, and therefore resisting the displacement. Coring out the shaft removes the lightly-stretched central atoms while leaving the atoms actually seeing the most stress. Also, consider the stretched bonds on the edge are further from the axis of rotation and thus generate a higher moment.
Out of curiosity I wanted to find the internal radius of a hollow shaft that would maximize rigidity/weight. I calculated the moment of inertia ratio of the hollow shaft compared to a solid one, then calculated the mass ratio of the hollow shaft compared to a solid one. I then calculated inertia ratio/mass ratio. By setting the second derivative with respect to the inner radius equal to zero (maximizing), I found that the internal hole should have a radius equal to sqrt(3)/3 of the shaft radius (or 57.7%), which for a shaft of 0.5" diameter is 0.29" This shaft would have 66.6% the weight of a solid shaft, but maintain 88.9% the rigidity.
If molecular reactions are deterministic, are all universes identical?
RIP David Shafer: you will be missed
  #22   Spotlight this post!
Unread 18-12-2015, 17:53
mrnoble's Avatar
mrnoble mrnoble is offline
teacher/coach
FRC #1339 (Angelbotics)
Team Role: Coach
mrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond repute
http://youtu.be/ymrUYVZW844
Waffle's first run.
http://www.angelbotics.com
Remember why you're doing this.
  #23   Spotlight this post!
Unread 18-12-2015, 18:48
asid61's Avatar
asid61 asid61 is offline
AKA: Anand Rajamani
FRC #1072 (Harker Robotics)
Rookie Year: 2013
Waffle's first run.
I love that quick snap on the PVC, and the flawless lifting and lowering of it.
<Now accepting CAD requests and commissions>
  #24   Spotlight this post!
Unread 18-12-2015, 22:42
Bluman56's Avatar
Bluman56 Bluman56 is offline
Mentor Without Borders
AKA: Nikita
FRC #2579
Rookie Year: 2013
Bluman56 is a jewel in the roughBluman56 is a jewel in the roughBluman56 is a jewel in the roughBluman56 is a jewel in the rough
Waffle's first run.
This is very cool. Reminds me of 179s can manipulator that creatively utilized mecanum wheels.
I noticed it takes a bit of adjustment to get the grabber to snap onto the PVC tube properly. In a game where there may be many of these tubes, I would try to aim for a quick lock on the tube after your robot aligns with the edge of the box. I can imagine putting an encoder or (probably even better) a potentiometer to the extending mechanism to program it to stop going forward when the grabber is aligned with the pipe.
I'm curious what the team is doing (if anything) to address that.
  #25   Spotlight this post!
Unread 18-12-2015, 23:06
Sl3dman's Avatar
Rookie Year: 2015
Actually, we are indeed using an encoder (which is reset by some limit switches that the linkage hits when in its upright position) and a PID loop to track how far forward the linkage is from the robot. The only problem is that the pipe isn't always at the same position in the box which proves to be a challenge for automation. So we ended up deciding that it would be better to overshoot the game piece by a little bit rather than coming up short to it.
  #26   Spotlight this post!
Unread 23-12-2015, 11:21
mrnoble's Avatar
teacher/coach
Team Role: Coach
Gotta drop this here. The team is now competing to make the best off-season build video, and since this is the first one, I figured it should be shared.
https://m.youtube.com/watch?v=OSH0sN4_U5k
We had our "competition" with 2240 last Saturday. It was fun, and gratifying to see how the team's work paid off. The robot was as good as any practice bot during build season, in spite of limited hours and resources. It would have been nice to see additional sensors used, including more limit switches and a gyro, and of course drive practice is something we will always need more of. Nevertheless, I'm very proud of the team.
  #27   Spotlight this post!
Unread 06-01-2016, 15:55
End-Game's Avatar
AKA: Skipper
Rookie Year: 2012
We are releasing the CAD for Waffle, Available on our GrabCAD account.
Link to this here
https://workbench.grabcad.com/workbe...H0_vBO4C75WvaU
There are two new Reveal Videos on our Youtube account.
https://youtu.be/3aahoGNRPow
https://youtu.be/E5dKcjiZz3s
I hope everybody enjoys them.
Can't wait till Kickoff, good luck to everyone!
