Go to Post Building a robot is one thing - but the fun I have had with my mentors, parents, and other students on team outings is something I cherish. - SuperJake [more]
Unread 25-11-2015, 20:14
Asymons Asymons is offline
FRC #4716 (Purple Raiders)
Team Role: Driver
Rookie Year: 2013
Asymons is an unknown quantity at this point
Oscillating Motor - PID Subsystem
Hello CD,
Yet another PID help thread, I apologize, but my team and I were having troubles with implementation of the PID Subsystem to properly work with our elevator lift. Originally we had the lift just stop once it went over a certain setpoint(which worked to some degree) but we now wanted a more accurate and elegant solution.
Setup:
We have two standard CIM motors as the output, and one encoder as the input. There is no CAN, just PWM and regular victors being used.
Issue:
-The implementation of the PID Subsystem results in the motor reaching the desired setpoint; however, oscillates when it reaches it.
-When the Robot is disabled quickly after the fear that the oscillation will break the elevator, when it is re-enabled it continues the PID command right when enabled without any buttons pressed. When the robot code is re-deployed or reset, this does not happen.
Attempted Solutions:
-Followed the GearBots Example, seems to have had some success, except for the oscillation.
-Lower P constant (I and D have remained at 0). Seems to not work, it has went as low as 0.02.
-Change the isFinished() method within the command to instead of detect for onTarget() method to a custom method that implemented our old code of the lift stopping after a certain setpoint. Did not work as well.
-Changed Absolute Tolerance and even tried Percent Tolerance, these were set to 200 ticks for the former and 30% for the latter. Still oscillation.
The Code:
Subsystem
Code:
package org.usfirst.frc.team4716.robot.subsystems;
import org.usfirst.frc.team4716.robot.RobotMap;
import edu.wpi.first.wpilibj.DigitalInput;
import edu.wpi.first.wpilibj.Encoder;
import edu.wpi.first.wpilibj.SpeedController;
import edu.wpi.first.wpilibj.CounterBase.EncodingType;
import edu.wpi.first.wpilibj.Victor;
import edu.wpi.first.wpilibj.command.PIDSubsystem;
public class PIDElevator extends PIDSubsystem {
	private DigitalInput limitSwitch;
	private Encoder elevEncoder;
	private SpeedController m1,m2;
    // Initialize your subsystem here
    public PIDElevator() {
    	super("PIDElevator",0.1,0.0,0.0);
    	setAbsoluteTolerance(5);
    	getPIDController().setContinuous(false);
    	limitSwitch = new DigitalInput(1);
    	m1 = new Victor(4);
    	m2 = new Victor(5);
    	elevEncoder = new Encoder(RobotMap.ELEVATOR_ENCODER_PORT_1, RobotMap.ELEVATOR_ENCDER_PORT_2,
				  false, EncodingType.k4X);
        // Use these to get going:
        // setSetpoint() -  Sets where the PID controller should move the system
        //                  to
        // enable() - Enables the PID controller.
    public void initDefaultCommand() {
        // Set the default command for a subsystem here.
        //setDefaultCommand(new MySpecialCommand());
    protected double returnPIDInput() {
        // Return your input value for the PID loop
        // e.g. a sensor, like a potentiometer:
        // yourPot.getAverageVoltage() / kYourMaxVoltage;
    	return elevEncoder.pidGet();
    protected void usePIDOutput(double output) {
        // Use output to drive your system, like a motor
        // e.g. yourMotor.set(output);
    	m1.set(-output);
    	m2.set(-output);
    public boolean getLimit(){
    	return limitSwitch.get();
    public boolean isUp(double setpoint){
    	return (elevEncoder.get() >= setpoint) ? true:false;
    public void setMotor(double x){
    	m1.set(x);
    	m2.set(x);
Command
Code:
package org.usfirst.frc.team4716.robot.commands;
import org.usfirst.frc.team4716.robot.Robot;
import edu.wpi.first.wpilibj.command.Command;
public class SetElevatorSetpoint extends Command {
	private double setpoint;
    public SetElevatorSetpoint(double setpoint) {
        // Use requires() here to declare subsystem dependencies
        // eg. requires(chassis);
    	this.setpoint = setpoint;
    	requires(Robot.pidelevator);
    // Called just before this Command runs the first time
    protected void initialize() {
    	Robot.pidelevator.enable();
    	Robot.pidelevator.setSetpoint(setpoint);
    // Called repeatedly when this Command is scheduled to run
    protected void execute() {
    // Make this return true when this Command no longer needs to run execute()
    protected boolean isFinished() {
    	return Robot.pidelevator.onTarget();
    // Called once after isFinished returns true
    protected void end() {
    	Robot.pidelevator.disable();
    // Called when another command which requires one or more of the same
    // subsystems is scheduled to run
    protected void interrupted() {
Sorry if the post is a bit lengthy, I just wanted to give as much information as possible to reduce the amount of replies to clarify information.
