Go to Post Keep reading. - Billfred [more]
Unread 25-11-2015, 23:59
Phred7's Avatar
Phred7 Phred7 is offline
Team President
AKA: Walker Ward
FRC #2906 (Sentinel Prime)
Team Role: Electrical
Phred7 is an unknown quantity at this point
2016 kit of parts
My FRC team is attempting to decide what to put down for our FIRST Choice requests. We were unsure as to what things we would be receiving in this years kit. New set of electronics? New talons? If anyone has any insight on this We would appreciate a response. Thank you.
Walker Ward
Spanaway Lake High School
-FTC 5328 (14-18)
-FRC 2906 (15-18)
-2015-17 Team President
Unread 26-11-2015, 00:17
Rachel Lim Rachel Lim is offline
FRC #1868 (Space Cookies)
Team Role: Student
Rookie Year: 2014
Rachel Lim has a reputation beyond reputeRachel Lim has a reputation beyond reputeRachel Lim has a reputation beyond reputeRachel Lim has a reputation beyond reputeRachel Lim has a reputation beyond reputeRachel Lim has a reputation beyond reputeRachel Lim has a reputation beyond reputeRachel Lim has a reputation beyond reputeRachel Lim has a reputation beyond reputeRachel Lim has a reputation beyond reputeRachel Lim has a reputation beyond repute
Re: 2016 kit of parts
If you go into an individual part in FIRST choice, there is a table including one row labeled "In Kickoff Kit" that specifies whether it's in the KOP, and if so, whether the rookie kit, veteran kit, or both.
Mark McLeod's spreadsheet, posted here, includes a column about whether it's in the KOP and is probably the easiest way to find this information. I also copied the parts he listed as being in either kit below (details about which kit it's in are in the column to the right).
In addition to that, every team will get a voucher for 3 Victor SPs or 2 Talon SRXs (information form this blog post).
Code:
USB A Male to B Male, 2m, Black (fc16-067)						Rookie
Throttle Motor (fc16-019)								All
Teflon tape PTFE-1/4 (fc16-054)								Rookie
PSoC 5LP Prototyping Kit (fc16-030)							Rookie
Power Distribution Panel (fc16-023)							Rookie
Pneumatic Pressure Switch (fc16-069)							Rookie
Pneumatic Cylinder (fc16-097)								Rookie
Pneumatic Control Module (fc16-022)							Rookie
Parker Fitting Kit (fc16-104)								Rookie
Micro switch, set of 10 (fc16-037)							All
Industrial RJ45 Modular Plug (fc16-001)							All
igubal spherical rod end bearing EBRI-10R (fc16-057)					All
igubal spherical flange bearing EFOI-10R (fc16-058)					All
iglide plastic thrust washer (fc16-108)							All
iglide plastic sleeve bearing (fc16-107)						All
iglide plastic flange bearing (fc16-106)						All
iglide plastic clip bearing (fc16-109)							All
Freelin-Wade WhiteTubing (fc16-043)							Rookie
Freelin-Wade Transparent Blue Tubing (fc16-042)						Rookie
Freelin-Wade Red Tubing (fc16-041)							Rookie
Freelin-Wade Blue Tubing (fc16-040)							Rookie
Freelin-Wade Black Tubing (fc16-039)							Rookie
Compressor, Model 90C (fc16-102)							Rookie
Battery Connector from Anderson Power Products (fc16-008)				All
Air Volume Tank, 32 cu. in., Black Plastic AVT-PP-35 (fc16-021)				Rookie
2-Position & 4-Position Link Connectors, Qty 10 each with 6ft Cable (fc16-002)		All
12V Battery NP18-12 (fc16-036)								1/Veteran, 2/Rookie
Last edited by Rachel Lim : 26-11-2015 at 12:53. Reason: Removed the iglie PRT slewing ring from the KOP list
Unread 26-11-2015, 08:56
Mark McLeod's Avatar
Mark McLeod Mark McLeod is online now
Just Itinerant
AKA: Hey dad...Father...MARK
FRC #0358 (Robotic Eagles)
One error I made in that list that is NOT included in the KOP is the
iglideŽ PRT slewing ring (fc16-056)
And realize that for the pneumatic tubing rookies don't get a roll of each color, but just one random color.
Unread 26-11-2015, 11:01
GreyingJay GreyingJay is online now
Robonut
AKA: Mr. Lam
FRC #2706 (Merge Robotics)
Rookie Year: 2015
GreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond repute
Is this "in kickoff kit" flag considered trustworthy for 2016 or is it at all speculative or based only on previous history?
Unread 26-11-2015, 12:00
Just Itinerant
The AndyMark FIRST Choice pages for each of the items showing if it's in the kit is trustworthy for 2016.
My copying of the information is worth verifying however.
Unread 26-11-2015, 12:51
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Rookie Year: 2013
This data is posted on the FIRST Choice site powered by AndyMark, so I would consider it trustworthy, bordering on authoritative. Here's an example: the battery page. The first row of the Product Specifications table tells you that there is 1 for veterans and 2 for rookies.
Unread 26-11-2015, 13:06
Robonut
AKA: Mr. Lam
Rookie Year: 2015
Sounds good, thanks guys!
