#16
Re: [FF]: [FF] San Diego Regional
I'll Fill in the next.
Code:
The ULCAN 2486 8:15 8:16 The Breakfast Company 399 8:12 8:17 Koko's X-Cats 1972 8:09 8:18 FIRST Pick 2485 8:06 8:19 Bobo Brigade 2496 8:03 8:20 OrangeJuice 3255 8:00 8:21 Swamp Life 2445 7:57 8:22 Rotten Fruit Alliance 2102 7:54 8:23 Falcon 7:40 7:51 8:24 Broconnor 7:45 7:48 8:25 812 1148 1159 1266 1388 1572 1622 2339 2443 2504 2543 2658 2827 2839 2984 3021 3041 3128 3328 3341 3473 3486 3647 3704 3749 3882 3965 4014 4078 4139 4160 4486 4501 4578 4583 4616 4738 4913 4919 4984 5025 5137 5199 5209 5474 5477 5514 5627 5857 5884 5896 5995 Last edited by orangemoore : 29-11-2015 at 19:41. |
#17
1622 for Falcon.
#18
Are we good to continue in the absence of bam-bam?
Code:
The ULCAN 2486 8:15 8:16 The Breakfast Company 399 8:12 8:17 Koko's X-Cats 1972 8:09 8:18 FIRST Pick 2485 8:06 8:19 Bobo Brigade 2496 8:03 8:20 OrangeJuice 3255 8:00 8:21 Swamp Life 2445 7:57 8:22 Rotten Fruit Alliance 2102 7:54 8:23 Falcon 1622 7:51 8:24 Broconnor 7:45 7:48 8:25 812 1148 1159 1266 1388 1572 2339 2443 2504 2543 2658 2827 2839 2984 3021 3041 3128 3328 3341 3473 3486 3647 3704 3749 3882 3965 4014 4078 4139 4160 4486 4501 4578 4583 4616 4738 4913 4919 4984 5025 5137 5199 5209 5474 5477 5514 5627 5857 5884 5896 5995 |
#19
Team Broconnor would like to select 2443 and 1266
#20
Code:
The ULCAN 2486 8:15 8:16 The Breakfast Company 399 8:12 8:17 Koko's X-Cats 1972 8:09 8:18 FIRST Pick 2485 8:06 8:19 Bobo Brigade 2496 8:03 8:20 OrangeJuice 3255 8:00 8:21 Swamp Life 2445 7:57 8:22 Rotten Fruit Alliance 2102 7:54 8:23 Falcon 1622 7:51 8:24 Broconnor 2443 1266 8:25 812 1148 1159 1388 1572 2339 2504 2543 2658 2827 2839 2984 3021 3041 3128 3328 3341 3473 3486 3647 3704 3749 3882 3965 4014 4078 4139 4160 4486 4501 4578 4583 4616 4738 4913 4919 4984 5025 5137 5199 5209 5474 5477 5514 5627 5857 5884 5896 5995 |
#21
1388 for Falcon.
If a draft runner isn't present, but the draft is set up, then the draft can proceed as long as everybody stays in order. The draft stops when someone doesn't make a pick, essentially, until the draft runner shows up and fills that spot in. |
#22
RFA will take 1572
#23
Code:
The ULCAN 2486 8:15 8:16 The Breakfast Company 399 8:12 8:17 Koko's X-Cats 1972 8:09 8:18 FIRST Pick 2485 8:06 8:19 Bobo Brigade 2496 8:03 8:20 OrangeJuice 3255 8:00 8:21 Swamp Life 2445 7:57 8:22 Rotten Fruit Alliance 2102 1572 8:23 Falcon 1622 1388 8:24 Broconnor 2443 1266 8:25 812 1148 1159 2339 2504 2543 2658 2827 2839 2984 3021 3041 3128 3328 3341 3473 3486 3647 3704 3749 3882 3965 4014 4078 4139 4160 4486 4501 4578 4583 4616 4738 4913 4919 4984 5025 5137 5199 5209 5474 5477 5514 5627 5857 5884 5896 5995 |
#24
I'd say let's go ahead and continue--usually if one list is sent, the other is as well. That being said, if either list WAS sent, the draft will need to be reworked from point of skippage--in this case, Swamp Life's first pick.
#25
Code:
The ULCAN 2486 8:15 8:16 The Breakfast Company 399 8:12 8:17 Koko's X-Cats 1972 8:09 8:18 FIRST Pick 2485 8:06 8:19 Bobo Brigade 2496 8:03 8:20 OrangeJuice 3255 3965 8:21 Swamp Life 2445 5896 8:22 Rotten Fruit Alliance 2102 1572 8:23 Falcon 1622 1388 8:24 Broconnor 2443 1266 8:25 812 1148 1159 2339 2504 2543 2658 2827 2839 2984 3021 3041 3128 3328 3341 3473 3486 3647 3704 3749 3882 4014 4078 4139 4160 4486 4501 4578 4583 4616 4738 4913 4919 4984 5025 5137 5199 5209 5474 5477 5514 5627 5857 5884 5995 |
#26
Code:
The ULCAN 2486 8:15 8:16 The Breakfast Company 399 8:12 8:17 Koko's X-Cats 1972 8:09 8:18 FIRST Pick 2485 8:06 8:19 Bobo Brigade 2496 2339 8:20 OrangeJuice 3255 3965 8:21 Swamp Life 2445 5896 8:22 Rotten Fruit Alliance 2102 1572 8:23 Falcon 1622 1388 8:24 Broconnor 2443 1266 8:25 812 1148 1159 2504 2543 2658 2827 2839 2984 3021 3041 3128 3328 3341 3473 3486 3647 3704 3749 3882 4014 4078 4139 4160 4486 4501 4578 4583 4616 4738 4913 4919 4984 5025 5137 5199 5209 5474 5477 5514 5627 5857 5884 5995 |
#27
Bobo Brigade gets 2339 from randoms. FIRST Pick takes 5199.
#28
Code:
The ULCAN 2486 8:15 8:16 The Breakfast Company 399 8:12 8:17 Koko's X-Cats 1972 4486 8:18 FIRST Pick 2485 5199 8:19 Bobo Brigade 2496 2339 8:20 OrangeJuice 3255 3965 8:21 Swamp Life 2445 5896 8:22 Rotten Fruit Alliance 2102 1572 8:23 Falcon 1622 1388 8:24 Broconnor 2443 1266 8:25 812 1148 1159 2504 2543 2658 2827 2839 2984 3021 3041 3128 3328 3341 3473 3486 3647 3704 3749 3882 4014 4078 4139 4160 4501 4578 4583 4616 4738 4913 4919 4984 5025 5137 5209 5474 5477 5514 5627 5857 5884 5995 |
#29
The breakfast company selects 3882
#30
Code:
The ULCAN 2486 8:15 8:16 The Breakfast Company 399 3882 8:17 Koko's X-Cats 1972 4486 8:18 FIRST Pick 2485 5199 8:19 Bobo Brigade 2496 2339 8:20 OrangeJuice 3255 3965 8:21 Swamp Life 2445 5896 8:22 Rotten Fruit Alliance 2102 1572 8:23 Falcon 1622 1388 8:24 Broconnor 2443 1266 8:25 812 1148 1159 2504 2543 2658 2827 2839 2984 3021 3041 3128 3328 3341 3473 3486 3647 3704 3749 4014 4078 4139 4160 4501 4578 4583 4616 4738 4913 4919 4984 5025 5137 5209 5474 5477 5514 5627 5857 5884 5995 |
