Go to Post this is ridiculous, a complete waste of time, and probably not particularly effective. I love it! - The other Gabe [more]
Unread 30-11-2015, 14:02
SciBorg Dave SciBorg Dave is offline
AKA: Dave Tharp
FRC #5920 (VIKotics)
Rookie Year: 2012
SciBorg Dave is a splendid one to beholdSciBorg Dave is a splendid one to beholdSciBorg Dave is a splendid one to beholdSciBorg Dave is a splendid one to beholdSciBorg Dave is a splendid one to beholdSciBorg Dave is a splendid one to behold
Throttle Motor
Has anyone used Throttle Motor Denso AE235100-0160 on their robot ? If you have what function did you use this motor for ?
Thanks VIKotic/ SciBorg Dave
Unread 30-11-2015, 14:16
Knufire Knufire is offline
Rose-Hulman Institute of Technology
Rookie Year: 2010
Knufire has a reputation beyond reputeKnufire has a reputation beyond reputeKnufire has a reputation beyond reputeKnufire has a reputation beyond reputeKnufire has a reputation beyond reputeKnufire has a reputation beyond reputeKnufire has a reputation beyond reputeKnufire has a reputation beyond reputeKnufire has a reputation beyond reputeKnufire has a reputation beyond reputeKnufire has a reputation beyond repute
Re: Throttle Motor
In 2012, 469 coupled it to a small leadscrew to tilt the shooter up and down.
For what it's worth, every inspector we had that year told it was the first time they'd seen someone use it on their robot.
Team 469: 2010 - 2013
Team 5188: 2014 - 2016
NAR (VEX U): 2014 - Present
Unread 30-11-2015, 14:24
Thad House Thad House is offline
Volunteer, WPILib Contributor
no team (Waiting for 2021)
Rookie Year: 2010
Thad House has a reputation beyond reputeThad House has a reputation beyond reputeThad House has a reputation beyond reputeThad House has a reputation beyond reputeThad House has a reputation beyond reputeThad House has a reputation beyond reputeThad House has a reputation beyond reputeThad House has a reputation beyond reputeThad House has a reputation beyond reputeThad House has a reputation beyond reputeThad House has a reputation beyond repute
Re: Throttle Motor
Well that was the first year it was legal
We always think about it, and then realize there are much better motors that are much easier to use. The power pins on the front require some really interesting configurations to get working. In addition, there are no COTS gearboxes that work with them.
All statements made are my own and not the feelings of any of my affiliated teams.
Teams 1510 and 2898 - Student 2010-2012
Team 4488 - Mentor 2013-2016
Co-developer of RobotDotNet, a .NET port of the WPILib.
Unread 30-11-2015, 14:26
AKA: Dave Tharp
Rookie Year: 2012
Re: Throttle Motor
A gear box for this motor maybe a good project for some team.
Unread 30-11-2015, 14:34
Lil' Lavery Lil' Lavery is offline
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
Lil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond repute
Send a message via AIM to Lil' Lavery
Re: Throttle Motor
Why would a team waste time finding a way to gear down an 18W motor when there are a plethora of better options available? There are equally compact motors that interface much more cleanly and provide much more power. Further still, if you have a low power, low speed application, the window motor already provides an option without additional external gearing.
I see no reason to use the throttle motor, personally.
Being correct doesn't mean you don't have to explain yourself.
Unread 30-11-2015, 14:25
AKA: Dave Tharp
Rookie Year: 2012
Re: Throttle Motor
I have not seen this motor used on any robot. I like the motor and am trying to find a good use for it.
Unread 30-11-2015, 14:38
Andrew Schreiber Andrew Schreiber is offline
Data Nerd
FRC #0079
Rookie Year: 2000
Andrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond repute
Re: Throttle Motor
Didn't 1640 use it for doing speed feedback on their shooter some year too?
Unread 30-11-2015, 14:55
Gdeaver Gdeaver is offline
FRC #1640
Gdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond repute
Re: Throttle Motor
Yes, 1640 did use it as a tachometer for the ball shooter. That year our programmers were stretched on other things and there was not time for them to get up to speed on quadrature and PIDS. So we attached the throttle motor to the shaft and ran it in to a rc filter. They had an analog voltage from o to 8 volts. What the programming team did from there I don't remember. It worked. Since then the programming team has learned to deal with encoders.
Unread 30-11-2015, 15:52
mman1506's Avatar
mman1506 mman1506 is offline
Focusing on Combat Robots!
AKA: Marcus Quintilian
no team (WARP7)
Rookie Year: 2012
mman1506 has a reputation beyond reputemman1506 has a reputation beyond reputemman1506 has a reputation beyond reputemman1506 has a reputation beyond reputemman1506 has a reputation beyond reputemman1506 has a reputation beyond reputemman1506 has a reputation beyond reputemman1506 has a reputation beyond reputemman1506 has a reputation beyond reputemman1506 has a reputation beyond reputemman1506 has a reputation beyond repute
4678 used one this year with 3D printed gears and gearbox. If I remember correctly they managed to print a gear that matches the pinion permanently attached to the motor. Maybe one of their members could chime in and provide more info.
2014-2015: FRC 865 Warp7 Team Captain
2016: FRC 865 Mentor
Unread 30-11-2015, 16:35
Jon Stratis's Avatar
Electrical/Programming Mentor
FRC #2177 (The Robettes)
Re: Throttle Motor
We had worked out a way to couple it to an existing PG gearbox from AndyMark to use as a steering motor for a swerve drive. We prototyped the coupler and knew that would work, but we never got around to building it into a swerve drive and testing that part out. Our driver for that was the fact that we could use 4 of them and had no place else we would want to use them - if they would work there, it would be great. Of course, just as we were about to start testing it, FIRST started allowing more and more motors... So, that project was shelved, as there are better and easier motors to use for that now that we don't have to worry about quantity. Of course, that could all change again...
2007 - Present: Mentor, 2177 The Robettes
LRI: North Star 2012-2016; Lake Superior 2013-2014; MN State Tournament 2013-2014, 2016; Galileo 2016; Iowa 2017
2015: North Star Regional Volunteer of the Year
2016: Lake Superior WFFA
Unread 02-12-2015, 21:09
sysdes sysdes is offline
Engineering Mentor
AKA: Maurice Veldhuis
FRC #4678 (CyberCavs)
Rookie Year: 2013
sysdes has a brilliant futuresysdes has a brilliant futuresysdes has a brilliant futuresysdes has a brilliant futuresysdes has a brilliant futuresysdes has a brilliant futuresysdes has a brilliant futuresysdes has a brilliant futuresysdes has a brilliant futuresysdes has a brilliant futuresysdes has a brilliant future
Re: Throttle Motor
Yes, we did use one on our Recycle Rush robot at the IRI. We added the ability to pick up the 3rd can in order to manage a 28 point autonomous. The throttle motor drives a 3D printed sprocket on a hex shaft with a 10-turn pot mounted on the other end. We had fairly strong string wrap around the hex shaft and it had no problem lifting the can off the ground in less than 2 seconds. We did a 28 point autonomous a couple of times (see match Q4 of the 2015 IRI) The lifting mechanism was strong enough to lift the can right up sideways and bust the string (Q73) when our autonomous didn't complete properly. This messed us up big time and we scored 0 points for our alliance that round. Anyways, the throttle motor can certainly work and using a 3D printed gear to get a 15:1 gear ratio worked very well. I'm pretty sure the gear was strong enough to stall the motor without breaking teeth. You can see the 3D image here. http://www.cybercavs.com/throttle-motor.html
Maurice Veldhuis
Engineering Mentor, team 4678, Woodland CyberCavs
Unread 30-11-2015, 17:27
Ari423's Avatar
Ari423 Ari423 is offline
LabVIEW aficionado and robot addict
AKA: The guy with the yellow hat
FRC #5987 (Galaxia)
Rookie Year: 2012
Ari423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant future
Re: Throttle Motor
We have bags full of them that we rarely if ever use. The only occasion I can think of when we used one was in 2013 to pull a pin on a spring-loaded flap that was too tall to start the match open so we pulled the pin in auton and it stayed open for the rest of the match. When we did that, we used it with a gearbox like the one shown in the picture below.
2017-present: Mentor FRC 5987
2017-present: CSA for FIRST in Israel
2012-2016: Member FRC 423
2013: Programmer
2014: Head Programmer, Wiring
2015: Head Programmer, Wiring
2016: Captain, Head Programmer, Wiring, Manipulator, Chassis, CAD, Business, Outreach (basically everything)
Unread 30-11-2015, 18:36
AKA: Dave Tharp
Rookie Year: 2012
Re: Throttle Motor
So it is the power source on the window motor ?
Unread 30-11-2015, 18:38
AdamHeard's Avatar
Lead Mentor
FRC #0973 (Greybots)
Re: Throttle Motor
The window motor is a different (but very similar) motor.
  #15   Spotlight this post!
Unread 30-11-2015, 19:08
pilleya's Avatar
pilleya pilleya is offline
Elec+Mech
AKA: Alastair Pilley
FRC #4613 (Barker Redbacks)
Team Role: Mechanical
Rookie Year: 2013
pilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond repute
Re: Throttle Motor
Hi I am a member of team 4613 Barker Redbacks, we have designed a low cost, low part count gearbox which gives the motor a 7.5:1 gear reduction, with a ½ hex output shaft. Our team has the capacity to manufacture these gearboxes in-house and we have partnered with a local sponsor. We are going to donate 40 of these gearbox kits to rookie teams in countries where it can be difficult to get parts like Australia, Brazil, Turkey and China among others. We will also spread the project to the FRC community by encouraging teams who have access to similar machining resources and distribute the gearboxes to teams in their area.
We have been in contact with Frank and he has confirmed that the throttle motor will be legal and sent out in the KOP once again in 2016(but with the FirstChoice release, we already knew this)
We have already made several systems utilising the gearbox we have designed, including a Polycord intake.
More information about the project will soon be on our website: www.team4613.org
