Go to Post Sometimes in discussions regarding rules or differences of opinion, the threads start feeling like a dog chasing its tail, going round and round. - JaneYoung [more]
Go Back   Chief Delphi > Technical > CAD > Inventor
  #16   Spotlight this post!
Unread 06-12-2015, 22:01
protoserge's Avatar
protoserge protoserge is online now
CAD, machining, circuits, fun!
AKA: Some call me... Tim?
FRC #0365 (MOE) & former 836 Mentor)
protoserge has a reputation beyond reputeprotoserge has a reputation beyond reputeprotoserge has a reputation beyond reputeprotoserge has a reputation beyond reputeprotoserge has a reputation beyond reputeprotoserge has a reputation beyond reputeprotoserge has a reputation beyond reputeprotoserge has a reputation beyond reputeprotoserge has a reputation beyond reputeprotoserge has a reputation beyond reputeprotoserge has a reputation beyond repute
Re: HSM Express+Tormach undersized holes
If it's thin as aluminum foil, it is likely just the variation in the material wall thickness. As suggested, machine to a lower depth.
I wouldn't be too worried about the thin layer if it happens again. Poke it with a punch and run a deburring tool to trim the leftover and you'll be fine.
Edit: I missed the bottom height offset. That will work as well.
Now, test out some higher speeds and feeds and post some videos of the tests!
  #17   Spotlight this post!
Unread 06-12-2015, 22:28
cgmv123's Avatar
cgmv123 cgmv123 is offline
FRC RI/FLL Field Manager
AKA: Max Vrany
FRC #1306 (BadgerBOTS)
Rookie Year: 2011
cgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond repute
Bottom offset is the setting you want. Just make sure you get the sign right.
BadgerBOTS Robotics|@team1306|Facebook: BadgerBOTS
2016 FIRST Championship Tesla Division | 2016 Wisconsin Regional Engineering Inspiration Award
2015 FIRST Championship Carson Division | 2015 Wisconsin Regional Chairman's Award
2013 FIRST Championship Curie Division | 2013 Wisconsin Regional Chairman's Award
2012 FIRST Championship Archimedes Division | 2012 Wisconsin Regional Engineering Inspiration Award, Woodie Flowers Finalist Award (Lead Mentor Ben Senson)
  #18   Spotlight this post!
Unread 07-12-2015, 08:42
Hadi379's Avatar
Hadi379 Hadi379 is offline
FRC #0379
Hadi379 is a splendid one to beholdHadi379 is a splendid one to beholdHadi379 is a splendid one to beholdHadi379 is a splendid one to beholdHadi379 is a splendid one to beholdHadi379 is a splendid one to beholdHadi379 is a splendid one to behold
On the first question, I'd be willing to bet your running a roughing process for the bearing hole and it needs a finishing process to remove the remaining material.
In the second scenario, I've experienced this quite a bit on my tormach. I would either use a deburring tool to remove the foil, or set my zero for the Z axis a tad bit lower than actual zero. This happens sometimes based on how the workpiece is clamped down, which can cause the material to bow in the center, or pick up on one end.
  #19   Spotlight this post!
Unread 07-12-2015, 13:50
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
FRC #0254 (The Cheesy Poofs)
Maybe this is a function of how HSMExpress works, but I don't really understand why this is even a problem. Aren't you hand entering a depth to cut to? Or is it selecting that depth based on the depth of the chain you selected?
If it's the former, just put in -.1875 or -.250 for a .125" wall thickness tube.
2001-2004: Team 100
2006-Present: Team 254
  #20   Spotlight this post!
Unread 07-12-2015, 14:41
billbo911's Avatar
billbo911 billbo911 is offline
I prefer you give a perfect effort.
AKA: That's "Mr. Bill"
FRC #2073 (EagleForce)
billbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond repute
HSMExpress selects the depth of cut based on the contour/profile you select. So, if the part being milled is modeled with a wall thickness of .125", but in reality has a wall thickness of .127", in a perfect world, the milling operation leaves .002" of aluminum at the bottom of the hole.
What I have found is that if I just set the "Bottom Height Offset" to a value of .010", then the end mill will extend .010" beyond the selected profile. This will cut the hole cleanly as long as the material being milled is less than .010" thicker than the expected .125".
CalGames 2009 Autonomous Champion Award winner
Sacramento 2010 Creativity in Design winner, Sacramento 2010 Quarter finalist
2011 Sacramento Finalist, 2011 Madtown Engineering Inspiration Award.
2012 Sacramento Semi-Finals, 2012 Sacramento Innovation in Control Award, 2012 SVR Judges Award.
2012 CalGames Autonomous Challenge Award winner ($$$).
2014 2X Rockwell Automation: Innovation in Control Award (CVR and SAC). Curie Division Gracious Professionalism Award.
2014 Capital City Classic Winner AND Runner Up. Madtown Throwdown: Runner up.
2015 Innovation in Control Award, Sacramento.
2016 Chezy Champs Finalist, 2016 MTTD Finalist
  #21   Spotlight this post!
Unread 07-12-2015, 14:57
R.C.'s Avatar
R.C. R.C. is offline
2017... Oooh Kill em, Swerve!
AKA: Owner, WestCoast Products
FRC #1323 (MadTown Robotics)
R.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond repute
Odd when I use MasterCAM for solidworks it does a similar thing by picking the depth of the chain selected. But like Cory I just over write the value and add .125 more to the depth. Especially in tubing. Is this not an option in hsm?
R.C.
Owner, WestCoast Products || Twitter
MadTown Robotics Team 1323
  #22   Spotlight this post!
Unread 07-12-2015, 15:16
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Team Role: Teacher
Chains? Haha, you MasterCAM folks are funny.
  #23   Spotlight this post!
Unread 07-12-2015, 15:24
protoserge's Avatar
It should be covered with the "Bottom Height Offset" option.
  #24   Spotlight this post!
Unread 07-12-2015, 15:39
Cory's Avatar
AKA: Cory McBride
It's still a chain, even if it's selecting the feature.
2001-2004: Team 100
  #25   Spotlight this post!
Unread 07-12-2015, 16:39
Jared's Avatar
Jared Jared is offline
Rookie Year: 2012
Jared has a reputation beyond reputeJared has a reputation beyond reputeJared has a reputation beyond reputeJared has a reputation beyond reputeJared has a reputation beyond reputeJared has a reputation beyond reputeJared has a reputation beyond reputeJared has a reputation beyond reputeJared has a reputation beyond reputeJared has a reputation beyond reputeJared has a reputation beyond repute
I like to create a few planes in SW model for depths/clearance heights and set the toolpath to use those planes, rather than entering a bunch of offsets. This way I only have to figure out depth and clearance/retract plane locations once. The default clearance plane is a little excessive.
For depth, I would try to go as deep as possible. You'll get more rigidity and you'll use the part of the end mill that's likely used less, so you'll get more tool life.
HSMWorks calls them contours.
