Go to Post ...the hardest part of engineering is communication. - EricVanWyk [more]
  #16   Spotlight this post!
Unread 09-12-2015, 19:22
s_forbes's Avatar
s_forbes s_forbes is offline
anonymous internet person
FRC #0842 (Falcon Robotics)
s_forbes has a reputation beyond reputes_forbes has a reputation beyond reputes_forbes has a reputation beyond reputes_forbes has a reputation beyond reputes_forbes has a reputation beyond reputes_forbes has a reputation beyond reputes_forbes has a reputation beyond reputes_forbes has a reputation beyond reputes_forbes has a reputation beyond reputes_forbes has a reputation beyond reputes_forbes has a reputation beyond repute
Re: pic: 2015 Off-season Single Speed Coaxial Swerve Chassis
Looking at the other renderings you posted (here and here), I have to complement you on such a spiffy design. You guys sure do a good job of removing excess material.
What is the part number on the large bearing used for the pivoting axis of the module?
  #17   Spotlight this post!
Unread 09-12-2015, 20:49
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Rookie Year: 2013
Originally Posted by Sh1ine View Post
... I am really impressed that the motors are stationary in this design. I feel ignorant, but what separates a swerve drive from a coaxial swerve? ...
That's the practical point of coaxial - the motor cases are stationary relative to the chassis. Coaxial swerve means that at some point, the steering bearings and the drive axle bearings have the same axis. The far more common configuration is similar to this, where the drive axle goes through the steering bearing.
Also, the wheels look to be 4" diameter, based on a 2.5" diameter CIM.
  #18   Spotlight this post!
Unread 09-12-2015, 21:23
asid61's Avatar
asid61 asid61 is offline
AKA: Anand Rajamani
FRC #0115 (MVRT)
Team Role: Mechanical
Rookie Year: 2013
To add to this, the purpose of going coaxial is usually to prevent wires from being tangled; in a non-coaxial swerve, the motor turns with the module, so a 360* turn would be a full twist of the wires.
<Now accepting CAD requests and commissions>
  #19   Spotlight this post!
Unread 10-12-2015, 00:03
Chak Chak is offline
AKA: Thomas
FRC #4159 (Cardinalbotics)
Team Role: CAD
Rookie Year: 2014
Chak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant future
Originally Posted by Kevin Ainsworth View Post
To discuss configurations a little more. When designing the robot we can insert a Vex Versaplanetary gearbox into Solidworks and change it to any possible configuration. This is a tab that allows you to reconfigure an assembly automatically, once you've spent the time adding in all possible parts. You can hide ,surpress, change items in the assembly so that it "reconfigures" the assembly. We currently can change between single and double stage reduction. We can change between the Bag motor, RS550 and RS775 motors. We can change the output shaft options between the .375" hex, .500" hex, .500" round, and 8mm keyed CIM shaft. We can also change to a dual motor option. This all occurs with a click of a button on the same gearbox assembly. So there is no deleting and reinserting a new custom setup. There is no creating a custom assembly each time we need to insert a VersaPlaentary gearbox into the robot design. We should create a video sometime to show how to do this for the First community.
That's cool, I never thought about using configurations that way. I found configurations while exploring Solidworks, but I could never figure out how it could be useful. Would changing configurations change the weight on Solidworks too? Also, would you be able to reconfigure the gearbox after it's been mated to the robot?
+1 to sharing the file and/or a video making it.
  #20   Spotlight this post!
Unread 14-12-2015, 22:57
AKA: Thomas
Team Role: CAD
Rookie Year: 2014
After reading this, I just had to try it for myself. Here are my results. It has the new Versaplanetary encoder stage, but I decided not to include the motor choices in my version. It made more sense for me to separate the motors, which are bought separately. I would still want to see how you guys did it, and compare it with my own methods. It'll be interesting to see how the "experts" did it compared to my googled knowledge.
  #21   Spotlight this post!
Unread 14-12-2015, 23:38
z_beeblebrox's Avatar
z_beeblebrox z_beeblebrox is online now
Custom User Title
AKA: Cal
FRC #4183 (Bit Buckets)
Rookie Year: 2012
z_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond repute
Nice work! Mind if I use this in my CAD library?
2012 Utah Regional Rookie All-Star
2013 Phoenix Regional Judge's Award for "design process and prototyping"
2014 Hub City Regional Quality Award, Arizona Regional Excellence in Engineering Award
2015 Arizona East Regional Creativity Award, Winner
2016 Arizona North Regional Finalist, Arizona West Excellence in Engineering Award, Finalist
