Go to Post I can't wait until IFI starts their FRC sized competition and quickly overtakes FRC. - AdamHeard [more]
Unread 08-12-2015, 17:41
Chempros7 Chempros7 is offline
FRC #6015
Chempros7 is an unknown quantity at this point
Rookie KoP
Hello,
I am getting a rookie 2016 KoP this year and I'm very excited. I was wondering if anyone has a list of what is inside the KoP (obviously not game related materials). I wanted to know about a battery charger, but I figure an entire list may be more helpful. Thanks
Unread 08-12-2015, 17:59
Mark McLeod's Avatar
Mark McLeod Mark McLeod is online now
Just Itinerant
AKA: Hey dad...Father...MARK
FRC #0358 (Robotic Eagles)
Re: Rookie KoP
This year's list has not been published yet, except for the KOP items listed in FIRST Choice as being in the KOP.
USB A Male to B Male, 2m, Black (fc16-067)
Teflon tape PTFE-1/4 (fc16-054)
PSoC 5LP Prototyping Kit (fc16-030)
Power Distribution Panel (fc16-023)
Pneumatic Pressure Switch (fc16-069)
Pneumatic Cylinder (fc16-097)
Pneumatic Control Module (fc16-022)
Parker Fitting Kit (fc16-104)
Freelin-Wade Tubing (fc16-043)
Compressor, Model 90C (fc16-102)
Air Volume Tank, 32 cu. in., Black Plastic AVT-PP-35 (fc16-021)
Throttle Motor (fc16-019)
Micro switch, set of 10 (fc16-037)
Industrial RJ45 Modular Plug (fc16-001)
igubal spherical rod end bearing EBRI-10R (fc16-057)
igubal spherical flange bearing EFOI-10R (fc16-058)
iglide plastic thrust washer (fc16-108)
iglide plastic sleeve bearing (fc16-107)
iglide plastic flange bearing (fc16-106)
iglide plastic clip bearing (fc16-109)
Battery Connector from Anderson Power Products (fc16-008)
2-Position & 4-Position Link Connectors, Qty 10 each with 6ft Cable (fc16-002)
12V Battery NP18-12 (fc16-036)
You'll certainly get a full control system and everyone gets a new robot radio.
You can see what was in last season's KOP to get an idea of the kinds of items you might find.
http://archive.firstinspires.org/rob...5-kit-of-parts
Unread 08-12-2015, 18:02
jimbo493's Avatar
jimbo493 jimbo493 is offline
Quasi Mentor
AKA: Jimmy
FRC #3357 (The COMETS)
Team Role: Electrical
Rookie Year: 2011
jimbo493 is on a distinguished road
Re: Rookie KoP
This table shows the differences between the two as of last year, It could be different this year, but probably not a whole lot. And that means you will get a charger, but it would make sense to get a least a second one. At competitions you'll want to be charging all your batteries basically all the time, since it is good practice to swap batteries between matches, and unless you have like 10 or more new batteries, that means charging them throughout the day.
Also here is the KOP page where the contents were posted, along with the mentioned table from last year
EDIT: Got beaten to the reply button it looks like.
FTC Student 2011-2012 FRC Student 2012-2016
FIRST Alum/Quasi-Mentor 2016-present
