Go to Post (If Dean still says 'Nationals', how can you ridicule a rookie team for it? Come on.) - Amanda Morrison [more]
Unread 08-12-2015, 20:25
cpapplefamily cpapplefamily is offline
FRC #3244 (Granite City Gearheads)
Rookie Year: 2015
cpapplefamily has a spectacular aura aboutcpapplefamily has a spectacular aura about
Mecanum programming (java if it maters)
We are testing mecanum drive train in our preseason. Our wheels make an X when viewed from the top. We are using an xbox controller with one stick controling forward reverse (axis 0, axis 1 respectively) and axis 4 for rotation. Our forward/reverse and strife side to side work flawlessly. Our rotation does not. Seems the command is sent to the wheels 90 deg out of order. The motor spin is like strife only exactly wrong. Does this make sense? Do you have any insight?
Update :
We figured it out. We had the wrong two motors inverted. During rotation running the two rear motors where inverted. Turns out the left two motors required inverting.
Unread 08-12-2015, 21:29
Ari423's Avatar
Ari423 Ari423 is offline
LabVIEW aficionado and robot addict
AKA: The guy with the yellow hat
FRC #5987 (Galaxia)
Rookie Year: 2012
Ari423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud of
Re: Mecanum programming (java if it maters)
So then you're good? No more mecanum questions?
2017-present: Mentor FRC 5987
2017-present: CSA for FIRST in Israel
2012-2016: Member FRC 423
2013: Programmer
2014: Head Programmer, Wiring
2015: Head Programmer, Wiring
2016: Captain, Head Programmer, Wiring, Manipulator, Chassis, CAD, Business, Outreach (basically everything)
Unread 09-12-2015, 13:59
lucas.alvarez96's Avatar
lucas.alvarez96 lucas.alvarez96 is offline
AKA: Lucas Alvarez
FRC #2576 (Chilean Heart)
Rookie Year: 2013
lucas.alvarez96 is a name known to alllucas.alvarez96 is a name known to alllucas.alvarez96 is a name known to alllucas.alvarez96 is a name known to alllucas.alvarez96 is a name known to alllucas.alvarez96 is a name known to all
Even though you already solved it, I just wanted to add that the very first thing we do when debugging mecanum is disconnect every motor controller except one and try every direction, just to see if the wheel is spinning correctly. Rinse and repeat for every other wheel. That way you don't have to think to hard to find the wheels which are wired backwards.
FRC 2576 2015-2016: Mentor
FRC 2576 2013-2015: Programmer & Chairman's Presenter
Los Angeles Regional 2014: Regional Chairman's Award
Unread 12-12-2015, 19:03
Rookie Year: 2015
Thanks for chiming in with the tips. These pointer are good for any instance of robot code.
Unread 12-12-2015, 19:17
Christopher149 Christopher149 is offline
FRC #0857 (Superior Roboworks) FTC 10723 (SnowBots)
Rookie Year: 2007
Christopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond repute
I'll also mention that it's usually a good idea to initially test any drivetrain on blocks. In 2010 I think it was, we were doing mecanum for the first time, and using a 3-axis stick. We were confused as to why wheels where moving (seemingly full-tilt) when the stick was at neutral.
Turns out the axis at the base of the joystick was "twist" and "z" (I think), but the actual "twist" axis was called "throttle". So even if you think you know what you're doing, things can surprise you.
2015-present: FTC 10723 mentor
2012-present: 857 mentor
2008-2011: 857 student
2015: Industrial Design, Excellence in Engineering, District Finalist, Archimedes Division (#6 alliance captain)
2014: Judges Award, District Engineering Inspiration, District Finalist, Galileo Division
Unread 14-12-2015, 14:57
Rookie Year: 2015
You quickly figure that one out on your own BUT NEEDS TO BE NOTED. I had my first ever PID controlled drive train attack me. Encoders needed to be reversed. Error ran away
