Go to Post If you need persuasion woven tight with logic, leave it to a software architect. - Richard Wallace [more]
Unread 20-12-2015, 15:33
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Rookie Year: 2013
Re: VEXpro 2016
Originally Posted by cadandcookies View Post
When I asked this a few years ago, here's the answer Aren gave me.
I'd assume the answer is somewhat similar here-- the arc motion is so short, and the cylinder and bar are very well defined, so it isn't necessary to connect the two.
Originally Posted by AllenGregoryIV View Post
Nick has it right. If you have omni wheels floating, you can just leave them and they won't hurt your driving. If you float traction wheels you would probably need to add a spring to raise the module to keep it from scrubbing during turns.
I think that it is necessary to raise the omni wheel, because it is geared twice as fast as the fixed wheel; it would be spinning against the carpet whenever you were driving in traction generating heat and wearing down the wheel. In Aren's previous answer, he refers to a spring lifting the moving wheel up. I don't see one in the assembly directions, but it may be implicit in the way pieces fit.
Unread 20-12-2015, 15:52
AllenGregoryIV's Avatar
AllenGregoryIV AllenGregoryIV is offline
Engineering Coach
AKA: Allen "JAG" Gregory
FRC #3847 (Spectrum)
Team Role: Coach
AllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond repute
Send a message via AIM to AllenGregoryIV
Re: VEXpro 2016
It won't really wear the wheels since there is no down force on the wheel other then the weight of the module itself.
Team 647 | Cyber Wolf Corps | Alumni | 2003-2006 | Shoemaker HS
Team 2587 | DiscoBots | Mentor | 2008-2011 | Rice University / Houston Food Bank
Team 3847 | Spectrum | Coach | 2012-20... | St Agnes Academy
LRI | Alamo Regional | 2014-20...
"Competition has been shown to be useful up to a certain point and no further, but cooperation, which is the thing we must strive for today, begins where competition leaves off." - Franklin D. Roosevelt
Unread 01-01-2016, 22:59
s_forbes's Avatar
s_forbes s_forbes is offline
anonymous internet person
FRC #0842 (Falcon Robotics)
s_forbes has a reputation beyond reputes_forbes has a reputation beyond reputes_forbes has a reputation beyond reputes_forbes has a reputation beyond reputes_forbes has a reputation beyond reputes_forbes has a reputation beyond reputes_forbes has a reputation beyond reputes_forbes has a reputation beyond reputes_forbes has a reputation beyond reputes_forbes has a reputation beyond reputes_forbes has a reputation beyond repute
Re: VEXpro 2016
Regarding motors.vex.com:
The link for the locked rotor stall test data exists for all of the motors, but returns a 404 for the CIM and BAG motor. The data seems to exist for the other motors... Is this just an error in the site? (obligatory "fix plox")
Unread 04-01-2016, 18:46
Grant Cox's Avatar
Grant Cox Grant Cox is offline
Back for more.
FRC #0148 (Robowranglers)
Team Role: Tactician
Rookie Year: 2007
Grant Cox has a reputation beyond reputeGrant Cox has a reputation beyond reputeGrant Cox has a reputation beyond reputeGrant Cox has a reputation beyond reputeGrant Cox has a reputation beyond reputeGrant Cox has a reputation beyond reputeGrant Cox has a reputation beyond reputeGrant Cox has a reputation beyond reputeGrant Cox has a reputation beyond reputeGrant Cox has a reputation beyond reputeGrant Cox has a reputation beyond repute
Re: VEXpro 2016
Whoops.. Thanks for pointing that out! This has been fixed.
For future reference, you can also let us know about website errors by emailing prosupport [at] vex [dot] com directly - you will likely receive a result quicker than by posting on Chief Delphi!
VEX Robotics Marketing Manager
ThunderChicken driver '07-'08
Robowrangler '13-present
FIRST in Michigan, VEX Worlds, and FIRST in Texas MC/Game Announcer '08-present
