Rotary encoders vs. price
I'm having trouble reconciling what differentiates popular FRC rotary encoders, especially since their price varies so much. For example, based on DigiKey:
I know max RPM and mechanical life varies between each encoder, but what else accounts for each sensor's price difference/popularity? |
Re: Rotary encoders vs. price
Another good option is CUI's AMT-102V. It's $24, has up to 2048 counts per revolution and is easy to mount. We used them extensively in the 2015 season and expect to continue in 2016.
Grayhills are also sealed and require no assembly (read: stupid-proof). This is why we use them.
AS5145B - low RPM, magnet must be positioned very precisely
TT 6120 -- haven't looked at this before -- isn't it a position sensor, not an encoder? |
Some more options...
CTRE Magnetic Encoder (absolute within one rotation and relative - we make this one) These are unique in that it uses the same cabling as Talon SRX, so they plug right into the Talon. http://www.ctr-electronics.com/srx-m...c-encoder.html If you are using Versa, there is a slice with same CTRE sensor built in. http://www.vexrobotics.com/vexpro/al.../217-5046.html Another analog encoder (MA3 US digital) I've used and seen teams use (absolute within one rotation) http://www.usdigital.com/products/en...tary/shaft/ma3 Another popular quadrature encoder(relative - us digital) I've used and seen teams use. http://www.usdigital.com/products/e4p |
Alot of the popularity comes from how easy they are to mount. For example the greyhills yoy can easily zip tie down the wire and attach to a shaft via surgical tubing (so I hear). To some teams that justify the price. I perfer the CUI ATM-102V encoders because of the price, that said they are a pain to mount, but for my team that is a sacrifice we are willing to make.
