Go to Post I may be right or wrong but I’ll be happily senile doing it. - ebarker [more]
Unread 11-12-2015, 13:07
Ari423's Avatar
Ari423 Ari423 is offline
LabVIEW aficionado and robot addict
AKA: The guy with the yellow hat
FRC #5987 (Galaxia)
Rookie Year: 2012
Ari423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant future
WiFi Router Bridge
So I had an idea and I was wondering whether it would be possible to implement. My school, like most, has a number of WiFi routers all bridged together into one large network, which spans practically the entire school. Since the school's walls are mainly stone, the one router on the robot sometimes has trouble going around corners or reaching far distances, especially when connecting to our old programming laptops. I was wondering whether we would be able to format the robot's router as a bridge and bridge it with the school's network like any of the routers that are actually part of the system. Then, we would be able to sign onto the school's network and control the robot from anywhere in the school. I'm sure someone on here knows enough about WiFi routers and the robot control system to let me know if this idea is something that could possibly work or if there is a big problem with it. Thanks.
2017-present: Mentor FRC 5987
2017-present: CSA for FIRST in Israel
2012-2016: Member FRC 423
2013: Programmer
2014: Head Programmer, Wiring
2015: Head Programmer, Wiring
2016: Captain, Head Programmer, Wiring, Manipulator, Chassis, CAD, Business, Outreach (basically everything)
Unread 11-12-2015, 13:10
Tim Sharp Tim Sharp is offline
Tim Sharp
FRC #3959 (Morgan County Mech Tech)
Team Role: Coach
Rookie Year: 2012
Tim Sharp is a splendid one to beholdTim Sharp is a splendid one to beholdTim Sharp is a splendid one to beholdTim Sharp is a splendid one to beholdTim Sharp is a splendid one to beholdTim Sharp is a splendid one to beholdTim Sharp is a splendid one to behold
Re: WiFi Router Bridge
We tried something similar to that a couple of years ago without success. The robot didn't like the network protocols. It had to do with administrator privileges. We ended up removing everything from the school network and creating our own, stand alone wireless hub.
Unread 12-01-2016, 01:04
Scott L.'s Avatar
Scott L. Scott L. is offline
FRC #0222 (Tigertrons)
Rookie Year: 1998
Scott L. is just really niceScott L. is just really niceScott L. is just really niceScott L. is just really niceScott L. is just really nice
Send a message via AIM to Scott L.
Lightbulb Re: WiFi Router Bridge
maybe use this on the robot, https://www.ubnt.com/unifi/unifi-ap-ac-pro/
You can do anything, if you put your mind to it!!!
http://asp.shinraikon.com
Unread 12-01-2016, 06:42
weaversam8 weaversam8 is offline
Team Captain
AKA: Sam Weaver
FRC #4534 (Wired Wizards)
Team Role: Leadership
Rookie Year: 2014
weaversam8 is a splendid one to beholdweaversam8 is a splendid one to beholdweaversam8 is a splendid one to beholdweaversam8 is a splendid one to beholdweaversam8 is a splendid one to beholdweaversam8 is a splendid one to behold
The AP acts in bridge mode at competitions to connect to the field management system anyways, you'd just need to determine that protocol and adjust your school network to comply with it.
ORB Haow!
