Re: FRC T-bone-ing and Hexagonal drive
Dear Enterprising Student, It's not a good idea. Sincerely, Every Other Team |
The important thing to remember here is that a hexagonal frame perimeter is an ENHANCEMENT and not a necessity. Don't sacrifice build time to design a hexagonal drivetrain unless you think that t-bones are what's holding you back.
In my opinion, only the top ~5% of FRC teams can both benefit from a hexagonal drivetrain and have the resources to build one without sacrificing elsewhere on the robot. |
In 2014 3467 had some extra edges up our sides which were a necessity for our shooter packaging and not added for t-bones which ended up being a benefit in a heavily defensive game. We poured a lot of time and effort into the frame extensions, bumpers, mounting, & maintenance that didn't need to be spent there. I wouldn't advocate building another frame like that in the future and fully agree with Ty that unless you have an higher level of manpower, experience, & resources you should probably avoid trying this during build season. To help with t-bones I would prefer a drop down omni wheel or ball caster that teams can easily remove or add depending on their needs without locking our drivebase into a specific design/layout early in the year. Personally the bumper construction & mounting is what makes this frame style very hard to pull off easily. Quote:
![]() Last edited by BrendanB : 13-12-2015 at 22:33. |
Right now on 3476, we are practicing sowing with these new materials, that's more important to us then working with a new hex frame. |
T-boning is when one team is pushing against the side of another robot, creating a T shape if both robots are long or both robots are wide.
Sometimes hexagonal bumpers help so that a team can only push their bumpers against a component angle of your side bumpers, allowing you to get out of a T-bone. Depending on how the team T-boning you orients themselves, hexagonal bumpers may not work. Watch defense played on 971 in this match. Occasionally when a robot makes contact to the side of their robot, they can roll out quickly. Occasionally they can't. https://youtu.be/G07Ci0VcUjs?t=40s It certainly can't hurt to make your bumpers hexagonal, but you should ask yourself two questions before you decide to do so. Is my team a major target of defense? Is this the most effective use of my resources in handling defenders? |
#10
T-bone-ing is when one robot's front pushes another robot's side. If the robot being pushed has traction wheels, this increases the friction on the pushed robot's wheels to the point where it cannot move. It is debated whether or not this should count as a pin, but as of 2014 it did not.
By hexagonal drive do you mean a normal robot with a hexagonal perimeter or a drive system where each side has an omni wheel? EDIT: sniped x3 Last edited by Ari423 : 13-12-2015 at 12:22. Reason: apparently I'm a really slow typer |
