pic: 4183 Custom Machined Wheel
Re: pic: 4183 Custom Machined Wheel
How creative! Have you done any strength tests on it yet? How much does it weigh?
We haven't done any testing yet. According to my cheesy kitchen scale this one minus the hub and hardware is just over 120 grams, and there's a lot of room for cutting more material out.
Looks good!
What are the dimensions of the wheel? I'm impressed with how light it is; a 4" HiGrip wheel from AndyMark is 140 grams, and this seems like it's of comparable (greater?) strength to the commonly used plastic wheels. |
Being a team that works with wood a tremendous amount, you probably know... but is a .5" hex sufficient for a wood drive wheel (even if it's only ~4" diameter)? I would think you'd at least want to make sure the interface didn't have slop.
It sounds like the intent is to place a hub in these wheels.
As I read it, the hex hole in the wood isn't for torque transfer, but presumably for alignment. |
Hey now! I can read perfectly fine!!!
#10
Looks cool! Can't tell if you have flange(s) to help hold tread in place, or perhaps you don't need it?
#11
Also, if the flanged side is towards the inside of the robot, it should help handle the sideways load on the tread in the worst condition (being pushed sideways by another robot). Most of the load in that case is taken by the center wheel opposite the side that's being pushed. Maybe just one flange would be okay. |
#12
Do you have an old operable robot base you can swap these onto and test them out? Not a bad idea for teams that lack machine shop capabilities.
