12V power supply for roborio
Has anyone ever powered a roboio (or cRio) using a plug-in 12 volt power supply? I was thinking that it would be convenient to power it that way instead of using the battery/PDP when testing out code to drive sensors, arduino, etc (anything with low current requirements).
I picture the 12 volt supply feeding directly into the PDB, or possibly right to the roborio (although that would bypass any over-voltage protection provided by the PDP). |
Re: 12V power supply for roborio
I use a 12v 2A wallwart directly into my roboRIO (but I'm not trying to run anything else). The only protection the PDP provides is a fuse.
We regularly power a robot control system with a 12v linear power supply. The one I have wired to an SB50 connector is capable of only a few amps, so we can't run any motors, but everything else works okay.
(Trying to use a switching power supply on the older PDB, with its own internal switching power supplies, was not a consistent success.) |
I've also used a 12v, 2A supply directly wired into the roboRIO. Something like this.
Also have used an old ATX computer power supply with the cRIO and roboRIO with no issues. |
In a pinch I used a CAN Connector to connect a 12V wall supply to andersons, and have been using it ever since [hey it works for power too
]I suppose I could have grabbed a RIO connector instead. |
Thanks for all the feedback - I feel more comfortable going forward. This will be a convenience as we are trying to step up our use of sensors and automation this year.
In past years we've used the power adapter included with the D-Link radios as a power source for cRIOs/RoboRIOs.
We have a 12V power supply we use to test both the cRIO/roboRIO for programming and the entire robot if we are doing long bench tests and don't want to have to keep switching batteries. |
I'm thinking about getting one of these for our benchbot
http://www.ebay.com/itm/100-AMP-CONT...EAAOSwBahVA8Ar Supposedly 12 100 AMP - Put the normal connector on it (Anderson? ) and use it through the pdp just like it was a battery. I'm thking 100 AMP would be enough even to power 2 CIM's if they have no load on them right? |
#10
