FRC shifting gears
What do teams use to shift gears on gear boxes. Other motors? pneumatics?
Re: FRC shifting gears
Our team uses pancake Pneumatic cylinders from vex pro. They work quite well, allowing the robot to shift fast and reliably but require a pneumatic system. They can be found here: http://www.vexrobotics.com/217-2778.html
This would be a great question to use the search tool here on cd. There are quite a few threads about this subject.
Pneumatic cylinders usually, and in the old days I believe servos were more common than they are now.
Did you know that before 2005, every team got two shifting gearboxes in the KOP?* The thing is that most shifting gearboxes take force to shift. Servos have a hard time providing enough force to actually shift. Ball-shifters, I think are the exception for that, and a 3-speed ballshifter could really use a servo's "infinite" positioning, but as a general rule a short-throw small-bore cylinder per gearbox (and per gear change in the gearbox) say about a 1" throw 3/4" diameter unit in the old days, is by far preferable. Pancake cylinders are more common now because they're smaller, lighter, and don't take as much air. Servos are sluggish, and tend to need to be ganged together to shift. Ain't worth it. You could also use an electrical solenoid actuator, but the power limits on those are even more restrictive than on servos. *Two drill motor transmissions, to go with the drill motors generally used for drive. Shifting took a little machining, creativity, and luck during matches, but it was present. Before my time the full drill was included... |
What kind of force is needed? I saw a supershifter demo with a servo that put out around 9 lbs but it was no where near as snappy as the pistons.
60 psi on a 3/4" diameter cross-section seems to do the trick nicely. |
Doesn't look like people like it very much, and I don't see a power rating on it. |
You can get a lot of shifts out of a couple filled tanks. |
#10
Hands down pneumatics, you can not beat the snappy action of a pneumatic cylinder in this application.
#13
This might be the first year such automotive "door motor" devices are legal. You're breaking new ground here. I think it's a great idea, and if you make it work well you'll probably want to talk to AndyMark about how you mounted things.
#14
I just want to say how glad I am that First Newbie has been asking these questions. You'll go far by approaching problems this way. Way to go!
#15
Brought to you by the IACNAP campaign. |
