Go to Post Cameras, colors, and tetras, oh my! - galewind [more]
Unread 14-12-2015, 22:12
mrnoble's Avatar
mrnoble mrnoble is offline
teacher/coach
FRC #1339 (Angelbotics)
Team Role: Coach
mrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond repute
Three Mini-CIMs in a gearbox?
What do you think the results would be if three minis were used in place of two CIMs in a drive train? I know about the speed/power differences. Has anyone tried it? A couple advantages I can think of would be:
  • Reduction in space taken up by motors
  • Saving the most powerful motors for other applications
Anyway, just curious what y'all think.
Remember why you're doing this.
Unread 14-12-2015, 22:14
AdamHeard's Avatar
Lead Mentor
FRC #0973 (Greybots)
Re: Three Mini-CIMs in a gearbox?
It would work out to being roughly equivalent to two CIMs. Likely slightly lower power/weight in terms of motor thermal mass, so slightly more robust to overheating (which isn't really a concern for most teams in drive anyway).
Requires more speed controllers, wire etc...
Unread 14-12-2015, 22:15
jkelleyrtp's Avatar
jkelleyrtp jkelleyrtp is offline
Let's just build a robot
AKA: Jon Kelley
FRC #5511 (Cortechs Robotics)
Team Role: Mechanical
Rookie Year: 2014
jkelleyrtp is a glorious beacon of lightjkelleyrtp is a glorious beacon of lightjkelleyrtp is a glorious beacon of lightjkelleyrtp is a glorious beacon of lightjkelleyrtp is a glorious beacon of lightjkelleyrtp is a glorious beacon of light
If one min-icim has around 2/3 the power output of a normal cim, the why not just use 2 cims? I understand that the power output does not directly correlate to speed and torque, but you will start to see limits of the mini-cims before you see it on the cims.
Cortechs Robotics 2014-Present
Mechanical, CAD
Unread 14-12-2015, 22:51
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Rookie Year: 2013
Because of the extra motor controller required, and the increased cost/weight/complexity of a 3 motor gearbox, you would almost have to be in some sort of edge case in order to want to make this trade. That said, I can think of a number of those cases pretty easily:
  • Out of CIMs according to rules (most likely useful only if CIMs and Mini-CIMs draw large currents at different times)
  • You need a bit of extra torque-to-speed trade space (e.g. for a lifter), but not enough to justify a shifter. This takes advantage of the fact that you can (for example) run 3 miniCIMS at a total of 120A for much longer than you can 2 CIMS without tripping breakers.
  • Short depth available behind gearbox
Unread 15-12-2015, 08:00
notmattlythgoe's Avatar
notmattlythgoe notmattlythgoe is offline
Flywheel Police
AKA: Matthew Lythgoe
FRC #2363 (Triple Helix)
notmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond repute
I could see using mini-cims in a drive train in a game list Recycle Rush where you might want to use the cims somewhere else and don't need that extra power in your drivetrain.
Unread 15-12-2015, 13:09
sastoller sastoller is offline
FRC #2122 (Team Tators)
sastoller is a splendid one to beholdsastoller is a splendid one to beholdsastoller is a splendid one to beholdsastoller is a splendid one to beholdsastoller is a splendid one to beholdsastoller is a splendid one to behold
We used a single mini CIM on each transmission last year give us more space for totes in our robots. The min CIMs gave us more distance between our transmissions, and saved us a little weight. The two mini CIM drivetrain was still sufficient to push our loaded robot around the carpet.
In addition, Vex has a fun little plot for the CIM and mini CIM motors on their website that shows a 3 minute peak power test. Looking at the two plots side-by-side, you can clearly see that the mini CIM has better peak power output characteristics (especially in the first 20 seconds of the test).
http://motors.vex.com/cim-motor
http://motors.vex.com/mini-cim-motor
2014 to present: Mentor on 2122
2008: Student on 2468
Maintain a healthy fear of what can go wrong
Unread 15-12-2015, 13:26
MichaelBick MichaelBick is offline
FRC #1836 (MilkenKnights)
Rookie Year: 2010
MichaelBick has a brilliant futureMichaelBick has a brilliant futureMichaelBick has a brilliant futureMichaelBick has a brilliant futureMichaelBick has a brilliant futureMichaelBick has a brilliant futureMichaelBick has a brilliant futureMichaelBick has a brilliant futureMichaelBick has a brilliant futureMichaelBick has a brilliant futureMichaelBick has a brilliant future
If I'm reading the graph correctly, the CIM produces higher power than the Mini CIM, though I assume it is also pulling more current.
Team 1836 - The Milken Knights
2013 LA Regional Champions with 1717 and 973
2012 LA Regional Finalists with 294 and 973
To follow Team 1836 on Facebook, go to http://www.facebook.com/MilkenKnights
To go to our website, go to http://milkenknights.com/index.html
Unread 15-12-2015, 15:05
mrnoble's Avatar
teacher/coach
Team Role: Coach
Here's my current belief: depending on the requirements of the game, using three minis in place of two CIMs is a viable option. I'd still love to hear from someone who's actually tried it. Thanks for musing on this point, folks
Unread 15-12-2015, 15:55
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Team Role: Teacher
We ran zero CIMs on our 2015 robot. We drove our swerve with four Mini-CIMs and it drove just fine for last year's game. In a game like 08, I'd want about 8 Mini-CIMs.
Unread 16-12-2015, 23:00
Unsung FIRST Hero Woodie Flowers Award
Chris Fultz Chris Fultz is offline
My Other Car is a 500 HP Turbine
FRC #0234 (Cyber Blue)
Rookie Year: 1942
Chris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond repute
This paper compares some different CIM - mini-CIM drive combinations.
http://www.chiefdelphi.com/media/papers/3071
Chris Fultz
Cyber Blue - Team 234
2016 IRI Planning Committee
2016 IndyRAGE Planning Committee
2010 - Woodie Flowers Award - Championship
Unread 16-12-2015, 23:19
BBray_T1296's Avatar
BBray_T1296 BBray_T1296 is offline
I am Dave! Yognaut
AKA: Brian Bray
FRC #1296 (Full Metal Jackets)
Rookie Year: 2010
BBray_T1296 has a reputation beyond reputeBBray_T1296 has a reputation beyond reputeBBray_T1296 has a reputation beyond reputeBBray_T1296 has a reputation beyond reputeBBray_T1296 has a reputation beyond reputeBBray_T1296 has a reputation beyond reputeBBray_T1296 has a reputation beyond reputeBBray_T1296 has a reputation beyond reputeBBray_T1296 has a reputation beyond reputeBBray_T1296 has a reputation beyond reputeBBray_T1296 has a reputation beyond repute
Another noteworthy point is thermal mass
Those power/time graphs are really showing functions of internal temperature. As the motor heats up, its performance diminishes and even after a match it takes a while for recuperation. source and source 2
3 miniCIMs weigh more than 2 CIMs, and thus have greater thermal mass. If both systems were loaded equally (and the motors were equally efficient) the decreased loading/motor and therefore amps/motor of the miniCIMs should result in them running cooler. This is not important on a 1 match basis, but in an eliminations scenario, every degree counts.
If molecular reactions are deterministic, are all universes identical?
RIP David Shafer: you will be missed
Unread 15-12-2015, 15:43
The miniCIM output power decreases less drastically than the CIM output power, especially when you look at the first 20 seconds of the curve, which is likely the area on the curve that most FRC robots operate on.
An interesting plot is to plot efficiency of the CIM vs miniCIM by time. Based on the Vex data, I think you will see the miniCIM is about 5% more efficient in the peak power test. When I ran a quick calculation, I assumed a 10.5V output for the CIM and 11V output for the miniCIM since the CIM pulls more current.
