Go to Post I didn't think it was possible for Dave to be any more cryptic. I was wrong. - IMDWalrus [more]
Unread 16-12-2015, 10:25
kprzewodek's Avatar
kprzewodek kprzewodek is offline
AKA: Kevin Przewodek
FRC #0862 (Lightning robotics)
Rookie Year: 2000
kprzewodek is an unknown quantity at this point
2016 Bosch motor 6004 RA3 194-06
Just wanted to start a thread for any questions, feedback, suggestions on this year’s first choice offering for the Bosch motor PN 6004 RA3 194-06. I work for Bosch in the motors division so I am familiar with the technical details on this motor. Also, I’m currently an FRC mentor and have been for the past 15 years (wow how time flies).
Hopefully teams find this a useful addition to the motor options. It’s best for a quick addition without much worry about custom gearing and fits a pocket in the options where you might want more torque than the window and snow blower motors offer. Of course at a cost of speed. With a build in thermal switch it is very unlikely to make magic smoke or destroy itself from overheating. It also has an integrated hall sensor which can be quite useful for position feedback and to give the programming teams something to play with. It’s good to see this option becoming more common in many of the KOP motors.
Some of the other Bosch teams had some initial samples to experiment with so may be able to share some early ideas on how best to utilize.
Interfacing with the start output might be the biggest challenge. Wish we had a hex output . Thoughts about 3d printing an interface has been brought up but needs to be experimented with since it may not be strong enough. Another option is if you can find or mill a square 6mm x 6mm steel or Aluminum shaft....or even mill down a hex shaft. It's very important that you have a tight fit since any slop with slowly start to strip out the connection and once that goes it's very hard to repair.
Unread 16-12-2015, 11:08
KrazyCarl92's Avatar
KrazyCarl92 KrazyCarl92 is offline
AKA: Carl Springli
FRC #5811 (The BONDS)(EWCP)
Rookie Year: 2010
KrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond repute
Re: 2016 Bosch motor 6004 RA3 194-06
I think this causes this motor to fall into a bit of a utility gap. Teams that have the ability to use the star output shaft may find their resources better suited to implementing a more powerful non-backdrive solution or integrating a sensor in a different design.
Last year, Team 20 actuated their forks by installing a BAG motor to the Window Motor gearbox with an encoder integrated between the BAG output shaft and the worm. More power, included sensor integration, and honestly not that much more difficult than dealing with that star output shaft.
Lower resource teams may be scared away by the star output, it is not easy to interface with at all.
I think if this had a 1/2" hex output you would have a lot more interest from teams. One application that comes to mind is the window motor shifters employed by Team 67 (I think they ditched that when they started using pneumatics?). The slow speed won't hurt you, and the added integrated position feedback might make it simpler to integrate.
[2016-present] FRC 5811 - BONDS Robotics
[2010-2015] FRC 0020 - The Rocketeers
Unread 16-12-2015, 12:24
kprzewodek's Avatar
Rookie Year: 2000
Agreed. It's why we opted not to include in the rookie KOP as the second low volume option. Maybe good for a medium resource team as I think there is a fairly simple way to mill a square interface into a hex shaft with a little patience. It's not a star but it gets you part of the way to an optimal solution.
Unread 16-12-2015, 12:52
RichQuinn's Avatar
RichQuinn RichQuinn is offline
FRC #5053 (Lakers)
Rookie Year: 2014
RichQuinn is an unknown quantity at this point
We received our first two samples of this motor last night and they looked very promising for light loads. I had a whole bunch of questions for you but then I realized most are answered here:
http://files.andymark.com/FRC_Bosch_...ec_sheetv1.pdf
One question remaining after reading the specs: Is it possible the output power curve is on an incorrectly labelled axis?
Example:
If you look at the peak power point at 11 N.m, the Input power should be 13V x 6A = 78 Watts.
The output power curve shows ~14W, and doublechecking torque & RPM confirms it at 13.8Watts
I don't expect high mechanical efficiency from a worm drive, but ~18% seems way off. Can you check and/or clarify? (Or correct me if I missed a unit conversion or decimal place.)
Regardless, it looks like a nice, light gearmotor option and the hall effect sensor makes it extra useful over a window motor. The challenge as you point out-- will be the relatively fragile output drive material, so that's a problem for us to solve. Square drive looks like an obvious solution, but more contact area would be better. Can you point us to a specific vehicle usage? We might be able to scrounge junkyard parts for the proper mating 8-point shaft. If the junction has survived automotive durability testing, it has a good shot at surviving FRC duty (if properly applied).
Unread 16-12-2015, 14:36
Nebster's Avatar
Nebster Nebster is offline
AKA: Ben Kishter
FRC #1306 (BadgerBOTS)
Team Role: Driver
Rookie Year: 2012
Nebster is an unknown quantity at this point
Are there any COTS 8 point shafts available? If not, what would you suggest we use? We don't have the machining capabilities to make one out of metal. My first thought was 3D printing, but testing would need to be done to see how much stress a 3D printed shaft/hub could take.
2015 Wisconsin Regional Chairman's Award - Carson Division
2013 Wisconsin Regional Chairman's Award - Curie Division
Unread 16-12-2015, 16:58
kprzewodek's Avatar
Rookie Year: 2000
This interfaces with quite a number of GM seats. It's a long list so I'll try to dig that out. It is specifically used for the recliner function in the power seats. I may have a few of these star shafts laying around that I can send if I find enough....maybe cut into pieces. I'll also see if we can find some scrap at our Tier 1.
Regarding efficiency I too was a bit surprised but that's what comes out of our dyno measurments. Actually too much efficiency is a problem in seat and window applications in that you don't want movement as the car bounces about on rough roads. In this motor there's a worm and two stages of spur gears for ~179:1 gear reduction.
Unread 16-12-2015, 17:12
topgun's Avatar
topgun topgun is offline
FRC #2846 (FireBears)
topgun has a brilliant futuretopgun has a brilliant futuretopgun has a brilliant futuretopgun has a brilliant futuretopgun has a brilliant futuretopgun has a brilliant futuretopgun has a brilliant futuretopgun has a brilliant futuretopgun has a brilliant futuretopgun has a brilliant futuretopgun has a brilliant future
Does anyone have a CAD file for it?
-T
Unread 16-12-2015, 17:22
kprzewodek's Avatar
Rookie Year: 2000
CAD model for the motor can be found at link through AndyMark. I should point out that there was an error in the first posted model which is currently in the process of being updated. I'll let you know when it is updated.
Unread 16-12-2015, 17:34
Bennett548 Bennett548 is offline
Engineering Mentor
AKA: Steve Bennett
FRC #0548 (Robostangs)
Bennett548 is just really niceBennett548 is just really niceBennett548 is just really niceBennett548 is just really nice
Have you tried drilling out the star pattern at 3/8" and broaching a key or a 3/8" hex?
This motor seems like a good choice when you would like to use a hobby servo motor, but need much more power (and have a home position sensor). The biggest issue I see with this motor is that it can't support any load on the output. In FRC we love to abuse our motors and gearboxes by hanging way too much weight on them.
Do you know if these will be available from AndyMark after First Choice is over?
Unread 16-12-2015, 21:35
bigbeezy's Avatar
bigbeezy bigbeezy is offline
AKA: Bryan
FRC #2338 (Gear it Forward)
Team Role: Coach
bigbeezy is a splendid one to beholdbigbeezy is a splendid one to beholdbigbeezy is a splendid one to beholdbigbeezy is a splendid one to beholdbigbeezy is a splendid one to beholdbigbeezy is a splendid one to beholdbigbeezy is a splendid one to beholdbigbeezy is a splendid one to behold
Send a message via AIM to bigbeezy
Would this kind of modification be legal? I know you can modify output shafts on motors but with this being internal does that make it different?
Team 1592 Bionic Tigers -- Driver 2005-2008
Winner - Florida Regional 2005
Finalist - Newton Division 2007
Winner - Colorado Regional 2008
Florida State University - BS Mechanical Engineering
Team 2338 Gear it Forward -- Mentor/Drive Coach 2013-Present
Winner - Wisconsin Regional 2013
Chairman's Award - Midwest Regional 2015
Winner - Archimedes Sub-Division 2015
Chairman's Award - Midwest Regional 2016
Unread 16-12-2015, 22:36
cgmv123's Avatar
cgmv123 cgmv123 is offline
FRC RI/FLL Field Manager
AKA: Max Vrany
Rookie Year: 2011
cgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond repute
Last year's rule says "The mounting brackets and/or output shaft/interface may be modified...". It seems like that modification would be covered by that wording.
BadgerBOTS Robotics|@team1306|Facebook: BadgerBOTS
2016 FIRST Championship Tesla Division | 2016 Wisconsin Regional Engineering Inspiration Award
2015 FIRST Championship Carson Division | 2015 Wisconsin Regional Chairman's Award
2013 FIRST Championship Curie Division | 2013 Wisconsin Regional Chairman's Award
2012 FIRST Championship Archimedes Division | 2012 Wisconsin Regional Engineering Inspiration Award, Woodie Flowers Finalist Award (Lead Mentor Ben Senson)
Unread 16-12-2015, 23:08
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
how to attach a lever to the motor (just guessing here) get one of these adapters, which you might already have in your toolbox.
Insert the square end into the star shaped hole in the motor. Might take some grinding to get it to fit.
then put a 1/4" combination wrench on the hex part of the adapter.
Unread 17-12-2015, 06:51
DaveL DaveL is offline
FRC #2976
DaveL is a jewel in the roughDaveL is a jewel in the roughDaveL is a jewel in the roughDaveL is a jewel in the rough
Are the internal gears metal?
How much torque can the output shaft experience before breaking an internal component?
Dave
Unread 17-12-2015, 09:08
kprzewodek's Avatar
Rookie Year: 2000
Dave
Internal gears are all plastic except for the worm. Hard to predict absolute limit since a lot depends on how well it is mounted and how tight the fit to the shaft and if it's a quick or slow force acting on it. These plastic gears will take quite a bit of abuse but something will crack or strip if lets say you have a long lever arm and smash into something.
We have a metal gear option but it was so heavy we decided not to offer it.
  #15   Spotlight this post!
Unread 17-12-2015, 09:13
kprzewodek's Avatar
Rookie Year: 2000
I did find a few options in a mechanics toolbox where the square part fit exactly. It was a non standard fitting though. Might take a little digging but it's out there. That is a good option for a quick and simple solution.
