Go to Post You will find friends among all FIRST students who will become very good friends of yours, will care and help you with anything that you need help with. This is my personal opinion, If you are hooked, dont ever let it go. - Arefin Bari [more]
Unread 17-12-2015, 05:36
NWChen's Avatar
NWChen NWChen is offline
Alum
Rookie Year: 2012
NWChen is a splendid one to beholdNWChen is a splendid one to beholdNWChen is a splendid one to beholdNWChen is a splendid one to beholdNWChen is a splendid one to beholdNWChen is a splendid one to beholdNWChen is a splendid one to behold
Smooth LED lighting
How do teams like 118 (2013) and 4488 (2014/2015) achieve relatively smooth lighting effects with LED lights, i.e. diffusing light so that individual LEDs are less discernible? Is this just a product of a neat hole pattern that obscures parts of the LEDs?
118 in 2013 for reference
4488 in 2015 for reference
2012 - 2015 • Team 2601
Unread 17-12-2015, 06:26
Sperkowsky's Avatar
Sperkowsky Sperkowsky is online now
Professional Multitasker
AKA: Samuel Perkowsky
FRC #2869 (Regal Eagles)
Team Role: Leadership
Rookie Year: 2014
Sperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond repute
Looks to me like they are behind a slightly frosted panel with LEDs on the top and bottom. Indirect led lighting is awesome.
Unread 17-12-2015, 07:41
EmileH's Avatar
EmileH EmileH is online now
it's not a water game, ok?
AKA: Emile Hamwey
FRC #1058 (PVC Pirates) & FF (NE Way You Want It)
Rookie Year: 2011
EmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant future
Re: Smooth LED lighting
They would put a strip of individually-addressable LEDs behind a frosted or matte panel, which would create the "blur" effect. I'd recommend a 60 or greater pixel-per-meter density for best effect. Pololu makes some good weatherproof LED strips.
2016-present: High School Student, FRC 1058 PVC Pirates
2016: RiverRage 20 Champions, Battle of the Bay 3 Champions
2013-2015: Middle School Student, FRC 3467 Windham Windup
Unread 17-12-2015, 10:04
otherguy's Avatar
otherguy otherguy is offline
sparkE
AKA: James
FRC #2168 (The Aluminum Falcons)
otherguy is a splendid one to beholdotherguy is a splendid one to beholdotherguy is a splendid one to beholdotherguy is a splendid one to beholdotherguy is a splendid one to beholdotherguy is a splendid one to beholdotherguy is a splendid one to behold
Don't know for sure, but I always assumed they used a thin (like 1/16") white acrylic sheet as a diffuser.
http://team2168.org
Unread 29-12-2015, 13:52
snekiam snekiam is offline
FRC #3322 (Eagle Imperium)
Rookie Year: 2010
snekiam has a spectacular aura aboutsnekiam has a spectacular aura aboutsnekiam has a spectacular aura about
I was talking with a member of 4488, the use this to diffuse their LEDs.
Unread 29-12-2015, 14:27
Thad House Thad House is offline
Volunteer, WPILib Contributor
no team (Waiting for 2021)
Rookie Year: 2010
Thad House has a reputation beyond reputeThad House has a reputation beyond reputeThad House has a reputation beyond reputeThad House has a reputation beyond reputeThad House has a reputation beyond reputeThad House has a reputation beyond reputeThad House has a reputation beyond reputeThad House has a reputation beyond reputeThad House has a reputation beyond reputeThad House has a reputation beyond reputeThad House has a reputation beyond repute
As said above, we use some thin diffuser paper taped to the inside of the rail behind the cutouts. The LED's are 60 led per meter NeoPixel strips, which are affixed along the inside of the rail for the entire length, which allows them to light both sides of the rails, which have cutouts.
All statements made are my own and not the feelings of any of my affiliated teams.
Teams 1510 and 2898 - Student 2010-2012
Team 4488 - Mentor 2013-2016
Co-developer of RobotDotNet, a .NET port of the WPILib.
Unread 29-12-2015, 15:54
asid61's Avatar
asid61 asid61 is offline
AKA: Anand Rajamani
FRC #0115 (MVRT)
Team Role: Mechanical
Rookie Year: 2013
How do you get them to sit evenly behind the rail? I would think that they would easily wrinkle or bend enough to distort the light.
<Now accepting CAD requests and commissions>
Unread 29-12-2015, 16:00
Rookie Year: 2010
The diffuser sheet is taped tight at the ends, with some small pieces of double sided tape in the middle at some of the cutouts to make sure it sits flat. And the lights are double sided tapes every foot or so along the lenght to make sure they sit flat. Plus far away you won't notice any distortion. We also run pneumatic and power wires up the same rails, and if you look up close you can see the shadows from them in the lights. However from more then 3 feet away its not noticeable.
Unread 29-12-2015, 16:35
BJT's Avatar
BJT BJT is offline
uh, should that be smoking?
AKA: Ben Thorsgard
FRC #0876 (Thunder Robotics)
BJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond repute
https://www.superbrightleds.com/more...-housing/2039/
we used a rail with a snap in diffuser like this
2016 Central Illinois Winner. Curie Division finalist
