pic: 3946 off-season strafe module, overhead view
Re: pic: 3946 off-season strafe module, overhead view
Is there any concern regarding the torque applied in the side-to-side direction to the hinge by the wheel/motor? Seems like there would be a little bit of pivot around that hinge that would cause material fatigue / potential failure.
Worst case scenario the piston shaft slightly bends. |
Both of these issues are being discussed at the thread on the oblique view.
The cylinder arm is mounted so that no transverse force can be applied. The hinge is a known concern, but it should be up to handling that torque; testing will tell. |
This is neat. I like the sanded-down HiGrip wheels used as spacers to keep the belts in line.
Looking forward to your test results. -Nick |
Same here. The team is taking the next two weeks off to catch up on sleep (and celebrate Christmas and New Year's and so forth), so the best chance for this to happen anytime soon is if we decide to go H-drive for some prototypes, or if we use this as a scrimmage base. |
Might be nice to mount a piece of 1x2 tube between the inner rails next to gearboxes and use the new VersaDrop module.
