Go to Post All battery terminals must be wrapped in tape or other insulating material AT ALL TIMES! - Al Skierkiewicz [more]
Unread 22-12-2015, 14:51
Rob Stehlik's Avatar
Rob Stehlik Rob Stehlik is offline
FRC #0610 (Coyotes)
Rob Stehlik is a glorious beacon of lightRob Stehlik is a glorious beacon of lightRob Stehlik is a glorious beacon of lightRob Stehlik is a glorious beacon of lightRob Stehlik is a glorious beacon of light
Wow, you guys are thinking about this a lot more than we did In our previous designs going back to 2010, roll pins are used in the corners of the tube to align them, and everything is held together with threaded rod. The reason then was it saved having to machine end blocks for the tubes. Now it's easier for us to make end blocks, and yet we still like the threaded rod. The frame joint feels a lot stiffer when you can preload it. Is this a significant difference? Probably not.
Unread 22-12-2015, 15:00
notmattlythgoe's Avatar
notmattlythgoe notmattlythgoe is offline
Flywheel Police
AKA: Matthew Lythgoe
FRC #2363 (Triple Helix)
notmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond repute
Re: 610's Preseason Drive
It looks like with 2.5" wide tube you can fit 2 sprockets and one of the 0.875" colsons inside of the tube. Would you guys consider doing something like this?
CAD
