Go to Post "FIRST, molding the future of America by inspiring children in the fields of science and technology....and eliminating playground dodgeball forever." - Andy Grady [more]
Go Back   Chief Delphi > Technical > Kit & Additional Hardware
Unread 20-12-2015, 20:46
klink135's Avatar
klink135 klink135 is online now
The one dat pushes da buttons
AKA: Max Jorgensen
FRC #5050 (Cow Town Robotics)
Rookie Year: 2015
klink135 is an unknown quantity at this point
Question Using an Andymark Arduino on a robot.
Hi! Our team for a practice project has been making a prototype garbage robot. We want Leds on it that change with controller input of the driver station. I have two questions
1. What are the options we have to make this system work.
2. If possible could we use the Roborio to give the Arduino the inputs.
Unread 20-12-2015, 21:12
KohKohPuffs KohKohPuffs is offline
AKA: Daniel Koh
FRC #0299 (Valkyrie Robotics)
Team Role: CAD
Rookie Year: 2013
KohKohPuffs has a spectacular aura aboutKohKohPuffs has a spectacular aura aboutKohKohPuffs has a spectacular aura about
Re: Using an Andymark Arduino on a robot.
I think roboRio has serial ports, and so does Arduino, so you can send data from the roboRio to the Arduino, and the Arduino can translate the data into something that can be run through a logic gate. RoboRio definitely has PWM outputs, and the Arduino can read that using analogRead() or something like that.
NOTE: I'm a CADer, not a coder nor electrical guy. So if I'm wrong... well... uh...
-KohKoh
115 MVRT, Driver (2013-2015)
649 M-SET, CAD (2015-2016)
299 Valkyrie Robotics, Mechanical Director (2016 - present)
Unread 20-12-2015, 21:15
EricH's Avatar
EricH EricH is offline
New year, new team
FRC #1197 (Torbots)
Arduino has USB (USB-B, I think). RoboRIO has USB. You should be able to use that to your advantage.
Past teams:
2003-2007: FRC0330 BeachBots
2008: FRC1135 Shmoebotics
Unread 20-12-2015, 21:46
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Rookie Year: 2013
Unless you need a larger number of ports, there isn't much you can do on the Arduino that you can't do with just the 'RIO. We controlled some RGB LEDs on our robot last year using a couple of relay ports and spikes, though we could have used 12V relay modules given the small current draw of the LED strips. If you do need an Arduino, I agree that USB is most likely your comms path of choice, because it is supported by hardware buffering and canned software classes on both sides of the connection.
Unread 20-12-2015, 21:49
Ari423's Avatar
Ari423 Ari423 is offline
LabVIEW aficionado and robot addict
AKA: The guy with the yellow hat
FRC #5987 (Galaxia)
Rookie Year: 2012
Ari423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant future
It has both USB-A (2x) and USB-B. I would imagine since most Arduinos use a mini- or micro- USB port (I can never remember which is which) you will have more luck finding a cable for the USB-A ports than the USB-B port. That being said, both have built-in libraries for Serial communication, so interfacing the two shouldn't be too difficult as long as you make sure they are encrypting and decrypting the Serial the same way. (Disclaimer: I haven't done this exactly before, but I did something similar using a PC instead of a RoboRIO)
2017-present: Mentor FRC 5987
2017-present: CSA for FIRST in Israel
2012-2016: Member FRC 423
2013: Programmer
2014: Head Programmer, Wiring
2015: Head Programmer, Wiring
2016: Captain, Head Programmer, Wiring, Manipulator, Chassis, CAD, Business, Outreach (basically everything)
Unread 20-12-2015, 23:26
Joe Ross Joe Ross is offline
FRC #0330 (Beachbots)
Rookie Year: 1997
The roboRIO can't control neopixel LEDs, which can do much more then the LED strips you used.
What USB library do you suggest for the roboRIO?
Unread 23-12-2015, 15:18
DrWaSaBi's Avatar
DrWaSaBi DrWaSaBi is offline
FRC #1711 (The RAPTORS)
Rookie Year: 2015
DrWaSaBi is an unknown quantity at this point
Unless it's the number of ports you need, or your loading some LED library. I would think you could drive them right from the RoboRio. Most LED strips I've seen just take some sort of pwm. I would think you could drive them direct.
Dr. W
Unread 23-12-2015, 15:50
techhelpbb's Avatar
techhelpbb techhelpbb is offline
FRC #0011 (MORT - Team 11)
Rookie Year: 1997
techhelpbb has a reputation beyond reputetechhelpbb has a reputation beyond reputetechhelpbb has a reputation beyond reputetechhelpbb has a reputation beyond reputetechhelpbb has a reputation beyond reputetechhelpbb has a reputation beyond reputetechhelpbb has a reputation beyond reputetechhelpbb has a reputation beyond reputetechhelpbb has a reputation beyond reputetechhelpbb has a reputation beyond reputetechhelpbb has a reputation beyond repute
This may help:
http://www.chiefdelphi.com/forums/sh...hreadid=131776
Unread 26-12-2015, 12:39
Greg Needel's Avatar Unsung FIRST Hero
Greg Needel Greg Needel is offline
REVving up for a new season
FRC #2848 (All-sparks)
Greg Needel has a reputation beyond reputeGreg Needel has a reputation beyond reputeGreg Needel has a reputation beyond reputeGreg Needel has a reputation beyond reputeGreg Needel has a reputation beyond reputeGreg Needel has a reputation beyond reputeGreg Needel has a reputation beyond reputeGreg Needel has a reputation beyond reputeGreg Needel has a reputation beyond reputeGreg Needel has a reputation beyond reputeGreg Needel has a reputation beyond repute
I think you should check out the RIOdunio. It is a custom arduino designed to talk to the roborio through the mxp port. You mention controlling LEd's we have a special breakout for neopixle strips on every RIOduino. They are also available from AndyMark.
http://www.andymark.com/product-p/am-2996.htm
Greg Needel│www.robogreg.com
Co-founder REV Robotics LLC www.REVrobotics.com
2014 FRC World Champions with 254, 469, & 74
