| View Poll Results: Favorite Motor Controller | |||
| Talon SRX |
58 | 49.57% |
| Victor SP |
29 | 24.79% |
| Jaguar |
4 | 3.42% |
| Spark |
13 | 11.11% |
| SD540 |
13 | 11.11% |
| Voters: 117. You may not vote on this poll | |||
Re: Motor Controllers
Ya my team also despises Jaguars
At this point, I'd still have to consider the Talon SR my favorite, based on the number of motors and hours we have utilized them with zero mishaps. Spike relays would be second for the same reason (no mishaps, fewer hours, though you may not consider them a controller).
It didn't take much use of the Talon SR to send the Jaguars and Victors (a few each 884s and 888s) into our "unused parts" collection. Being a bit of a "never buy serial number 1 of anything" guy, I have high hopes for most of the various controllers on this list, but none of them has become a favorite yet. I really like the features of the Talon SRX; if it proves to be robust it will probably top my list next year. The Victor SP, Spark, and SD 540 are all in a runoff to displace the obsolescent Talon SR, with cost, reliability, and limit switch capability as ranking factors to be determined. The Jaguar is my least favorite ever controller since becoming associated with FRC in 2012, squarely behind both the Victor 884s and 888s. Every one that the team ever owned has died a painful, stinky death. As much as we wanted to stop using them, we couldn't stop using these fast enough to get any of them out of use before it went up in smoke. For the record: no vote cast, because my only solid decision among the controllers listed is not jaguar. Edit: Ditto Talon SR. Last edited by GeeTwo : 22-12-2015 at 21:31. |
Wondering why Victor 884/888 was left out of voting yet Jaguar was included?
--Michael Blake |
simply because this is all of the current motor controllers, nothing as far as I know has been made to replace the jaguar.
Though they don't have the same name (because they're made by different companies IIRC) the Talon SRX effectively replaces the Jaguar. It does the same PID control, limit switches, etc with better CAN support. I wouldn't buy Jaguars new even if they still were for sale.
http://hansenhobbies.com/products/co...nlpconnectors/ http://hansenhobbies.com/products/co.../pt1in_lp_1x2/ |
So many fun things to consider.... |
The 2015 rules has a specific exception for wiring terminations to COTs devices. I would think the 2016 rules would have the same exception. We will see. As a robot inspector, this is not an area I would focus on unless told to anyway.
It is always a risk when "future proofing" something. What you may have done one year may not be legal the next. At the very least, one can use these motor controllers on a practice robot with very little effort.
#10
Talon SRX are my favorite. Unless you need the advanced features of the Talon the Victor SP makes more economic sense. I will wait to pass judgement on the new 2016 controllers when they prove their durability.
Other than size the jaguars don't deserve their bad reputation. We found them reliable when connected correct and not filled with metal shavings. ![]() |
#11
I could see the first task for a student in the pit being to crimp some connectors onto a set of spare motors and controllers, ready to go. In fact... *writes that down* As for the poll, I voted for Talon SRX since it seems to offer quite a lot of potential advantages for the fairly minimal extra cost. Virtually every one of our robot failures last year, both on our practice field and unfortunately during our first regional, was some combination of our software addressing the incorrect PWM or DIO, the encoder wired incorrectly, read incorrectly, software values set/reset incorrectly, motors trying to run the forklift past the edge (e.g. we didn't have time to wire in a hard limit switch), etc. If we thought to use the limit switch and encoder functionality in the Talon SRX, and communicate over CAN instead of PWMs and DIOs, our code (and failure modes) could have been much simpler. Last edited by GreyingJay : 23-12-2015 at 11:29. |
#13
Getting back on topic to answer OP's questions... As with most things in engineering design, the answer here is "it depends". In my mind there are three key features to look at: cost, capability and reliability. I am only going to focus on the controllers you can buy going forward (Talon SRX, Victor SP, REV Spark, MS SD540). Since you can't get spares for other controllers easily I would stay away from or use them sparingly (and with LOTS of spares ready just in case). Talon SRX at $90 is the most capable, but also the most expensive. Capability: Talon SRX allow use of a Controller Area Network (CAN) bus. The other option is Pulse Width Modulation (PWM). With a bus you get two way communication between controllers and the RoboRio. Also, the Talon SRX has an input data port that allows you to do some routine control calculations directly on the controller instead of using the RoboRio. You can hookup small breakout boards to the data port and do a number of control loops. Some examples are that you can hookup an encoder to a shaft and thru the data port and tell the motor controller to drive forward until the encoder has reached 1000 ticks and then stop. Another example is that you can tell the motor controller to drive forward until the upper limit switch on your elevator is tripped and then stop. With PWM the RoboRio has to check all these sensors and issue the commands to stop. Since the RoboRio is doing a lot of calculations it may be slower to respond (by some number of milliseconds) to when the switch is tripped on your elevator. The Talon SRX offloads these mundane control calculations from the RoboRio. Cost: You pay for all these nice features (CAN bus chip, extra connector for data port inputs). Over a whole bot this extra cost can add up. Reliability: Last season the Talon SRX performed well with few (if any) failures. Since there was no defense and therefore few long duration high current pushing matches, there could be an argument made that some more testing is needed under these extreme conditions. Most people would agree it is a solid and FRC tested design. It also has a very small foot print and a sealed aluminum enclosure. This prevents debris from getting in and shorting out electrical components (a problem with older controllers). Aluminum is a great heat conductor and allows the heat generated by the controller to be moved away from the electronic chips without the need for a separate fan. Victor SP at $60 is a robust, but basic controller. Capability: Talon SP is a simple Pulse Width Modulation (PWM) driven controller. No fancy data inputs, just the ability to set the speed between 0 and 100%. Cost: You pay for a smaller form factor and an aluminum case. More expensive than other PWM controllers and does not have data inputs. Reliability: Same as Talon SRX. Most would agree it is a proven, dependable controller for FRC. REV Spark at $45 is a new low cost controller with some nice looking features. Capability: REV Spark is a simple Pulse Width Modulation (PWM) driven controller. You can set the speed between 0 and 100%. It also has a basic input data port that will allow you to directly wire in a set of limit switches to stop it. These limit switches are great for an elevator or a rotary arm with a top/bottom limit switch. No fancy encoder or other control capabilities. Pretty impressive for such a low cost device. Cost: Cheapest one on the market for FRC right now. Reliability: This is brand new this year. Preliminary test data looks positive. It has a plastic case, which will not transfer heat as well as aluminum. It claims not to need fan cooling, which is being tested in lab conditions (I believe results release soon). Obviously the real test is to see it during the season. Be cautious about switching to a new controller with limited testing unless you can afford to replace the controllers. It is a bit larger than the Victor SP and Talon SRX. For the price it looks promising. MS SD540 at $50 is a new low cost controller with some nice looking features. The SD540 implements many of the same features that the REV Spark does, albeit in a different layout. There are some concerns about the design choices made for the SD540 that are detailed in another thread. Same overall story - low cost plastic body controller with PWM input and limit switch control build in. Untested. Hope that helps. PM me for more detail (I glossed some of the nitty gritty details) -matto- Last edited by aldaeron : 23-12-2015 at 15:18. Reason: Typo in SRX pricing |
#14
The footprint is close, but not identical to that of the Talon SR. |
#15
For effective thermal management I like mounting the controllers to a hefty aluminum frame member or sheet metal belly pan of decent thickness. Wood or plastic or heavily pocketed aluminum belly pans limit the ability to conduct heat away from the mounting location. Perhaps the REV will be fine for most situations, but what I said is still true - the Victor/Talon will be better because there is no plastic in the thermal conduction path. I believe REV is planning to release test data soon. Hopefully they will instrument down to the package level or heatsink right next to the MOSFET case and will provide ThetaJC values for the devices. The junction temperature is what is key for long term performance and reliability. It really depends on current draw of the motors and efficiency of the controllers during matches as to how much heat you really need to dump. But keep in mind that in a Best-of-3 Finals match that you do not have as much time to cool off as during a normal match. It can be a problem. TL DR: REV may be fine, but Victor/Talon will be better for dumping heat. -matto- |
