Presentation about the 2016 control system
Hi Gang,
Attached is a presentation that I gave at the Washington DC FIRST workshop earlier in December. I hope you enjoy. Regards, Mike Anderson FRC #116 |
Re: Presentation about the 2016 control system
Very thorough!
Minor nitpick, some of the Jaguar information in here is wrong: Quote:
Re: Presentation about the 2016 control system -- UPDATED
I'll make the change in the presentation to reflect the info. Thanks! |
Glad you are working to educate teams in your area.
Some further edits or clarifications for those that are reading this: - On slide 7 the UART being 5V is a warning. However, the UART (on MXP port) is the connection to use with Arduino, Pi, etc. The warning is for the 9V RS-232. - There is a new radio required this coming year (OM5P-AN). - On slide 24, it is said that you need to connect CAN if you want current-related data. It is required to connect CAN to the PDP period. This is how battery voltage shows up on the DS and I believe a robot will not pass inspection without it. - New CTRE magnetic encoder was part of the beta program. It plugs directly into the Talon SRX and can be used for both relative and absolute positioning simultaneously. |
Re: Presentation about the 2016 control system -- UPDATE #2
Mike |
DS batVoltage actually comes from the RIO. You can additionally read the PDP's report battery voltage through robot API and RIO-web-based config. PDP required for inspect was true last season. Won't know for sure for next season until kickoff. |
Also good catch on the Jags. You don't need a 2CAN to use Jags with roboRIO+CAN. The robotAPI was updated last year to use the onboard CANbus for Jags as well.
In other words, the differences in comms between RIO<=> Jag and RIO<=>TalonSRX is handled in software. Sorry Mike if that point wasn't communicated better. As much as I liked the 2CAN, we were very happy last year with integration of CANbus in the RIO (best for teams). |
Mike |
