Go to Post Ha, our 2009 robot's nickname was Sparky, for the same reason...we now have EXTRA fire extinguishers because of it ;P - Karibou [more]
Unread 23-12-2015, 14:48
nickbrickmaster's Avatar
nickbrickmaster nickbrickmaster is offline
Not Allowed Near Power Tools
AKA: Nick Schatz
FRC #3184 (Blaze Robotics)
Team Role: Leadership
Rookie Year: 2014
nickbrickmaster is an unknown quantity at this point
Introducing FRC Blocks - A starter program for FRC coding novices
FRC Blocks is a web interface that allows you to code FRC robots using an intuitive drag-and-drop interface. It compiles to Python in real time, allowing you to see the code that you "write". FRC Blocks is intended to be a bridge between drag-and-drop languages (scratch, labview) and more traditional programming languages.
FRC Blocks is great for:
  • Workshops
  • Demonstrations
  • Novice Programmers
I started this project as a way to get more members of my team involved in programming the robot, even if they have no prior experience or build season is only 3 weeks away.
Try it out (no persistence or runner)
View on GitHub
It's simple to install and use.
  1. Download FRC Blocks off github
  2. Install pyfrc on development computer and robot
  3. Start webserver (run.bat)
  4. Navigate to localhost:8000/cgi-bin/index.py
  5. Start coding! Use procedures named robotInit, teleopPeriodic, etc as starting points. All blocks are very similar to their robotpy counterparts.
Pneumatics, motors, some sensors, and joysticks are implemented. The live version does not spit out runnable code, as it needs a bootstrap IterativeRobot class, which is provided in the _runner.py file.
Disclaimer: I have not tried this on a robot yet. However, it works on the pyfrc simulator. I'll update this soon with info on robot testing.
I have approximate knowledge of many things.
FRC 3184: 2014-, FTC 10648: 2015-
Last edited by nickbrickmaster : 23-12-2015 at 23:56. Reason: Update to current version
Unread 23-12-2015, 15:22
DrWaSaBi's Avatar
DrWaSaBi DrWaSaBi is offline
FRC #1711 (The RAPTORS)
Rookie Year: 2015
DrWaSaBi is an unknown quantity at this point
Re: Introducing FRC Blocks - A starter program for FRC coding novices
Wow. Very cool. thanks for sharing. Will have to check it out in more detail tonight.
Dr W
Unread 23-12-2015, 16:04
Ari423's Avatar
Ari423 Ari423 is offline
LabVIEW aficionado and robot addict
AKA: The guy with the yellow hat
FRC #5987 (Galaxia)
Rookie Year: 2012
Ari423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud of
This looks really cool! It's a little confusing at first without any instructions, but I got the hang of it after a few minutes. I will have to show this to my new programmers to introduce them to robot programming (as opposed to regular programming). I would love to see a good set of instructions, and pneumatic control.
2017-present: Mentor FRC 5987
2017-present: CSA for FIRST in Israel
2012-2016: Member FRC 423
2013: Programmer
2014: Head Programmer, Wiring
2015: Head Programmer, Wiring
2016: Captain, Head Programmer, Wiring, Manipulator, Chassis, CAD, Business, Outreach (basically everything)
Unread 23-12-2015, 16:41
Foster Foster is offline
Engineering Program Management
VRC #8081 (STEMRobotics)
Foster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond repute
Blockly is cool, interesting the way that you've changed/extended it.
I've been using Snap! recently since it also allows you to create your own blocks.
How did you pick Blockly as your base?
Foster - VEX Delaware - 17 teams -- Chief Roboteer STEMRobotics.org
2010 - Mentor of the Year - VEX Clean Sweep World Championship
2006-2016, a decade of doing VEX, time really flies while having fun
Downingtown Area Robotics Web site and VEXMen Team Site come see what we can do for you.
Unread 23-12-2015, 17:09
AKA: Nick Schatz
Rookie Year: 2014
I've never heard of Snap! before now. I got this idea from MIT App Inventor 2, which uses Blockly.
Actually, after looking it up, I realize that I once used BYOB, a long while ago. Does that also compile to some language that uses wpilib?
Unread 23-12-2015, 19:25
If you run Snap! and go into the examples look for Codification. It's a short example that produces C, Smalltalk, Javascript and Python.
Unread 23-12-2015, 23:50
virtuald's Avatar
virtuald virtuald is offline
RobotPy Guy
AKA: Dustin Spicuzza
FRC #1418 (), FRC #1973, FRC #4796, FRC #6367 ()
virtuald has a brilliant futurevirtuald has a brilliant futurevirtuald has a brilliant futurevirtuald has a brilliant futurevirtuald has a brilliant futurevirtuald has a brilliant futurevirtuald has a brilliant futurevirtuald has a brilliant futurevirtuald has a brilliant futurevirtuald has a brilliant futurevirtuald has a brilliant future
Needs some refinement, but very cool.
Maintainer of RobotPy - Python for FRC
Creator of pyfrc (Robot Simulator + utilities for Python) and pynetworktables/pynetworktables2js (NetworkTables for Python & Javascript)
2017 Season: Teams #1973, #4796, #6369
Team #1418 (remote mentor): Newton Quarterfinalists, 2016 Chesapeake District Champion, 2x Innovation in Control award, 2x district event winner
Team #1418: 2015 DC Regional Innovation In Control Award, #2 seed; 2014 VA Industrial Design Award; 2014 Finalists in DC & VA
Team #2423: 2012 & 2013 Boston Regional Innovation in Control Award
Resources: FIRSTWiki (relaunched!) | My Software Stuff
