Go to Post Remember, FIRST is about people. Robots are just what bring us all together... - Matt Attallah [more]
Unread 23-12-2015, 16:59
alecmuller's Avatar
alecmuller alecmuller is offline
FRC #2342 (Phoenix Robotics)
Rookie Year: 2007
alecmuller will become famous soon enoughalecmuller will become famous soon enough
Easy Reversible Bumpers with CAD
We use reversible bumpers that change colors without removing the bumpers from the robot - it takes about 10 seconds to flip the fabric up or down and secure it with velcro. It's designed to the 2014 game rules (because bumpers weren't required in 2015 and the 2016 rules aren't out yet), so be sure to check the new rules.
This PDF, CAD model and drawing has all the information needed to make them, and the CAD is designed to be very easy to edit in SolidWorks: change two assembly cuts (see PDF) to make it fit your robot width & length (and adjust or suppress a third cut if you need clearance for part of your robot).
It includes a STEP file for importing into other CAD packages, and it's simple enough that you could probably skip CAD and just tweak the dimensions on the PDF too. The PDF includes sources for the fabric, pool noodles, and hardware.
The weights for the materials in the SolidWorks file are accurate - about 14.4 lbs (without the cutout) as designed for a ~27" x 28" robot.
