Go to Post The front page of the entire paper had the words "Gracious Professionalism" on the front cover. - Andy Baker [more]
Unread 28-12-2015, 16:37
frcguy's Avatar
frcguy frcguy is offline
Unregistered Unuser
AKA: Nicholas Dal Porto
FRC #5940 (B.R.E.A.D.)
Team Role: Tactician
Rookie Year: 2012
frcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond repute
Cannot connect to roboRIO over wifi
To prepare for the build season, my team built a Andymark AM14U2 with the full 2015 control system, except the newer Openmesh AP instead of the d-link. We have everything configured: the roboRIO imaged and java installed and openwrt installed on the Openmesh AP. We were able to download the example code and connect to the robot through the 2015 driver station while it was tethered over USB and get the motors to move. But, once we disconnected the USB cable, we were able to connect to our wifi network, but couldn't connect through driver station or the online configuration interface for the roboRIO. Firewall on the computer is set to allow connections through mDNS and driver station, and we are able to reach the configuration page for the AP. As we are a rookie team this year, we are stuck. Any help/suggestions would be appreciated. Thanks in advance!
Unread 29-12-2015, 00:29
Mark McLeod's Avatar
Just Itinerant
AKA: Hey dad...Father...MARK
FRC #0358 (Robotic Eagles)
Re: Cannot connect to roboRIO over wifi
Enable DHCP on the OpenMesh serving IP addresses in the 10.te.am.20 and higher range. (10.59.40.20 in your case)
You can also give the OpenMesh an IP of 10.te.am.1 to make some things easier on yourself. (10.59.40.1 in your case)
