Go to Post A year where the students learn a lot and win nothing is more rewarding than a year where the team does well and doesn't learn much. - Molten [more]
Unread 29-12-2015, 14:49
jkelleyrtp's Avatar
jkelleyrtp jkelleyrtp is offline
Let's just build a robot
AKA: Jon Kelley
FRC #5511 (Cortechs Robotics)
Team Role: Mechanical
Rookie Year: 2014
jkelleyrtp is a glorious beacon of lightjkelleyrtp is a glorious beacon of lightjkelleyrtp is a glorious beacon of lightjkelleyrtp is a glorious beacon of lightjkelleyrtp is a glorious beacon of lightjkelleyrtp is a glorious beacon of light
"W" Drive Versa Wheels
We're buying wheels right now and I was curious if anybody has experience with the "W" treaded versawheels. They seem to have a nice bite into the carpet and turn well (no lateral 'bite') as well as a 1.2 CoF. Also, they're .3lbs and only $5 so I think we're going to buy quite a few. Just curious about what people have to say about them...
Cortechs Robotics 2014-Present
Mechanical, CAD
Unread 29-12-2015, 14:56
Ty Tremblay's Avatar
Ty Tremblay Ty Tremblay is online now
Robotics Engineer
FRC #0319 (Big Bad Bob)
Ty Tremblay has a reputation beyond reputeTy Tremblay has a reputation beyond reputeTy Tremblay has a reputation beyond reputeTy Tremblay has a reputation beyond reputeTy Tremblay has a reputation beyond reputeTy Tremblay has a reputation beyond reputeTy Tremblay has a reputation beyond reputeTy Tremblay has a reputation beyond reputeTy Tremblay has a reputation beyond reputeTy Tremblay has a reputation beyond reputeTy Tremblay has a reputation beyond repute
Re: "W" Drive Versa Wheels
My second hand knowledge is that these wheels are known to wear quite fast, but I think that knowledge is from a year or two ago, so YMMV.
Unread 29-12-2015, 15:01
Lil' Lavery Lil' Lavery is online now
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
Lil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond repute
Send a message via AIM to Lil' Lavery
We used these wheels in 2013 and 2014, and were generally quite pleased. They have excellent traction, both in the forwards and lateral directions. When new, they almost act like cleats in the carpet.
The one thing to be aware of is that they wear rather quickly. Worn wheels do have both reduced traction and a smaller radius. This isn't a big issue if you have the money to replace them periodically (once per competition at bare minimum, once per day would be even better) and a drivetrain design that allows your wheels to be replaced swiftly. If you have a dead axle drive train that requires significant effort to take apart, I would suggest a lower maintenance wheel (such as Colsons).
Being correct doesn't mean you don't have to explain yourself.
Unread 29-12-2015, 15:23
jkelleyrtp's Avatar
AKA: Jon Kelley
Rookie Year: 2014
http://upurs.us/image/47366.jpeg
Oh man I didn't think it would be that bad...
Is there a healthy medium between colsons and high traction wheels? Something around the 1.1 range maybe. I know andymark has a deal on plaction wheels for around $7.50. We'd like to stick with Vex but would rather something more aggressive than colsons.
Mechanical, CAD
Unread 31-12-2015, 04:19
Joe G.'s Avatar
Joe G. Joe G. is offline
Taking a few years (mostly) off
AKA: Josepher
no team (Formerly 1687, 5400)
Rookie Year: 2007
Joe G. has a reputation beyond reputeJoe G. has a reputation beyond reputeJoe G. has a reputation beyond reputeJoe G. has a reputation beyond reputeJoe G. has a reputation beyond reputeJoe G. has a reputation beyond reputeJoe G. has a reputation beyond reputeJoe G. has a reputation beyond reputeJoe G. has a reputation beyond reputeJoe G. has a reputation beyond reputeJoe G. has a reputation beyond repute
Send a message via AIM to Joe G.
We did this to Colsons in 2014. Nasty, nasty traction. The individual segments flex and literally bite the carpet under load. They do wear faster than unmodified Colsons, but our robot played four events on the same wheels, and probably could have done another. All we did was rotate out the middle wheels to the ends after the second event.
We used the W tread wheels when they came out in 2013, and likely won't do so again. They wore quickly, and we also found their traction somewhat underwhelming.
FIRST is not about doing what you can with what you know. It is about doing what you thought impossible, with what you were inspired to become.
2007-2010: Student, FRC 1687, Highlander Robotics
2012-2014: Technical Mentor, FRC 1687, Highlander Robotics
2015-2016: Lead Mentor, FRC 5400, Team WARP
2016-???: Volunteer and freelance mentor-for-hire
Unread 31-12-2015, 06:07
AmiableVariable's Avatar
AmiableVariable AmiableVariable is offline
the ginger one
AKA: Hannah Fritsch
FRC #4488 (Shockwave)
Rookie Year: 2013
AmiableVariable is a name known to allAmiableVariable is a name known to allAmiableVariable is a name known to allAmiableVariable is a name known to allAmiableVariable is a name known to allAmiableVariable is a name known to all
We used those on our 2014 robot, as the dropped center wheels on a west coast drive, with a different, non-W tread set (same brand) on the front and back wheels. They worked pretty well, though we replaced them at least once per competition. We did manage to melt holes in the wheels during Galileo finals , but I think those were the outer wheels. Either way it's a good idea to be prepared to replace them.
Overall, we were pretty satisfied with how they worked.
Unread 31-12-2015, 12:16
jkelleyrtp's Avatar
AKA: Jon Kelley
Rookie Year: 2014
Thanks for all the response so far... Has anybody used this before? They look similar to the diamond tread but have a 1.1 CoF. We'll probably go down the colson route but I just want to verify all the options right now.
Mechanical, CAD
Unread 01-01-2016, 12:16
Dale's Avatar
Dale Dale is offline
Head Coach & Mentor
AKA: Dale Yocum
FRC #1540 (Flaming Chickens)
Team Role: Coach
Dale has much to be proud ofDale has much to be proud ofDale has much to be proud ofDale has much to be proud ofDale has much to be proud ofDale has much to be proud ofDale has much to be proud ofDale has much to be proud ofDale has much to be proud of
What we love about the W tread wheels is their lower lateral COF and crazy high COF in the direction of travel. This results in a robot that requires less power to turn because of lower scrub forces. Less scrub likely means more accurate turns as well. This is our go-to wheel. Wear hasn't been as big a problem for us but being able to change them out for each competition would be wise.
2016 PNW Championship Chairman's; 2016 Winner Oregon City District, 2015 PNW Championship Chairman's; 2015 PNW District Engineering Inspiration; 2015 PNW District Finalist; 2014 PNW Championship Chairman's; 2014 Championship Innovation in Controls; 2013 Chairman's (Oregon); 2013 Finalist (OKC); 2012 Winner (OKC); 2012 Chairman's (OKC); 2012 Woody Flowers (Oregon); 2011 Volunteer of the Year (Oregon); 2011 Finalist & Captain (San Diego); 2011 Innovation in Control (San Diego); 2010 & 2007 Chairman's (Oregon); 2010 Regional Champions (Colorado); 2010 Innovation in Control (Colorado); 2009 & 2008 Engineering Inspiration (Oregon); 2008 Regional Champions (Oregon); 2007 Regional Finalist (Oregon); 2005 Rookie Inspiration (PNW)
Unread 02-01-2016, 11:18
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
Originally Posted by Wayne TenBrink View Post
We have used them since 2014 and are inclined to use them again if they suit the game. In 2014 we replaced them about once per competition. In 2015 we ran the same set all season.
They don't get meaningfully smaller as they wear, but the sharp edges get rounded off and the CoF drops, requiring replacement (if you want to do well in a shoving match). We found that the tread tips on the corner wheels (8WD) wore in a "sawtooth" pattern, so we would swap them out end-for-end to stretch a few more matches out of the set.
I disagree on the bolded. In 2014, we noticed a difference in the distance we drove in autonomous on worn wheels compared to fresh ones (and our wear isn't as significant as what was shown in some pictures). The radius change is definitely a relevant concern as the wheels wear.
Unread 02-01-2016, 12:49
wmarshall11 wmarshall11 is online now
FRC #2399
Rookie Year: 2011
wmarshall11 is a splendid one to beholdwmarshall11 is a splendid one to beholdwmarshall11 is a splendid one to beholdwmarshall11 is a splendid one to beholdwmarshall11 is a splendid one to beholdwmarshall11 is a splendid one to beholdwmarshall11 is a splendid one to beholdwmarshall11 is a splendid one to behold
Originally Posted by Joe G. View Post
Image snip.
Seeing as the wheel pictured is from 11's 2014 robot, thought I'd chime in with a review.
We switched to the horizontal tread pictured after experimenting with a diamond pattern in 2013. The treading was done using a 1:1 scale drawing of the wheel with 0.5" cuts every 10° along the exterior that was taped to the stock wheel for alignment purposes. The horizontal tread was easier to apply than the diamond tread, since the diagonals required for the diamond required a jig to do consistently.
The wheels were solid performers on the field, performing the standard colson trick of getting grippier as they heated up. They wore about 1/16" during a 12 match + elims district event. We ended up swapping the center wheels with the outer wheels before elims at most events to ensure even-ish wear. They could have probably been run down quite a bit more without loss of traction, but there may have been issues with defeating the point of the dropped center. The wear pattern was interesting, rounding the points of the tread before eating away at the diameter, which created a sweet spot where the spread of each section would produce an almost flat profile on the ground.
Programming Project Manager and Lead Web Developer 2012 - 2014
Mount Olive Robotics Team, FRC 11
Mentor 2015 -
The Fighting Unicorns, FRC 2399
Unread 02-01-2016, 12:47
cbale2000's Avatar
cbale2000 cbale2000 is online now
AKA: Chris Bale
FRC #0703 (Phoenix)
Team Role: Leadership
cbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond repute
We've used the wheels, but we went with the roughtop tread option instead of the traction tires. Been using them for 2 years now with no complaints, still haven't found a robot our 2014 bot could not push.
Unread 29-12-2015, 15:24
headlight headlight is offline
Rookie Year: 2012
headlight is an unknown quantity at this point
During aerial assist we replaced those wheels probably 3 times an event. We found that rotating them on the drive train helped too, the dropped wheel set tends to wear faster.
Unread 29-12-2015, 15:32
mman1506's Avatar
mman1506 mman1506 is offline
Focusing on Combat Robots!
AKA: Marcus Quintilian
no team (WARP7)
Rookie Year: 2012
mman1506 has a reputation beyond reputemman1506 has a reputation beyond reputemman1506 has a reputation beyond reputemman1506 has a reputation beyond reputemman1506 has a reputation beyond reputemman1506 has a reputation beyond reputemman1506 has a reputation beyond reputemman1506 has a reputation beyond reputemman1506 has a reputation beyond reputemman1506 has a reputation beyond reputemman1506 has a reputation beyond repute
Give the colsons a chance. The traction is suprisgnly good.
We had a similar experience with plaction as others did with W tread in 2014. The year was a bit of an outlier in terms of tread wear.
2014-2015: FRC 865 Warp7 Team Captain
2016: FRC 865 Mentor
Unread 29-12-2015, 15:36
cadandcookies's Avatar
cadandcookies cadandcookies is offline
Director of Programs, GOFIRST
AKA: Nick Aarestad
FTC #9205 (The Iron Maidens)
cadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond repute
It's definitely worth mentioning what kind of tread you were using on the plaction wheels-- wedgetop, roughtop, blue nitrile, pebbled, etc all have different wear characteristics and CoF.
Never assume the motives of others are, to them, less noble than yours are to you. - John Perry Barlow
tumblr | twitter
'Snow Problem CAD Files: 2015 2016
MN FTC Field Manager, FTA, CSA, Emcee
FLL Maybe NXT Year (09-10) -> FRC 2220 (11-14) -> FTC 9205(14-?)/FRC 2667 (15-16)
VEXU UMN (2015-??)
Volunteer since 2011
2013 RCA Winner (North Star Regional) (2220)
2016 Connect Award Winner (North Super Regional and World Championship) (9205)
  #15   Spotlight this post!
Unread 29-12-2015, 15:53
mman1506's Avatar
no team (WARP7)
Rookie Year: 2012
We we're using blue nitrile roughtop(usually considered the most wear resistant) but my point is that tread that could of last a whole season in 2012, 2011,2010 etc may last a couple of matches in 2014.
