Go to Post If you can't make them fit on the robot, then those features don't really add much value. - Cory [more]
  #16   Spotlight this post!
Unread 31-12-2015, 20:34
mman1506's Avatar
mman1506 mman1506 is offline
Focusing on Combat Robots!
AKA: Marcus Quintilian
no team (WARP7)
Rookie Year: 2012
mman1506 has a reputation beyond reputemman1506 has a reputation beyond reputemman1506 has a reputation beyond reputemman1506 has a reputation beyond reputemman1506 has a reputation beyond reputemman1506 has a reputation beyond reputemman1506 has a reputation beyond reputemman1506 has a reputation beyond reputemman1506 has a reputation beyond reputemman1506 has a reputation beyond reputemman1506 has a reputation beyond repute
Originally Posted by BenGuy View Post
I think it should still be possible as it is totally hardware, no software at all, the only way that the Cube knows that something is installed is by a sensor in the bracket, if you leave an empty one there and just have a large and cheaper supply next to it, it should work perfectly fine as long as the stepper can pull it in well.
It keeps track of how much filament is extruded and writes that amount to a chip mounted on the filament. Once the printer uses a certain amount of filament it will say its empty even if filament is left on the reel.
2014-2015: FRC 865 Warp7 Team Captain
2016: FRC 865 Mentor
2017: Free Agent Mentor, Inspector
  #17   Spotlight this post!
Unread 01-01-2016, 21:40
BBray_T1296's Avatar
BBray_T1296 BBray_T1296 is offline
I am Dave! Yognaut
AKA: Brian Bray
FRC #1296 (Full Metal Jackets)
Rookie Year: 2010
BBray_T1296 has a reputation beyond reputeBBray_T1296 has a reputation beyond reputeBBray_T1296 has a reputation beyond reputeBBray_T1296 has a reputation beyond reputeBBray_T1296 has a reputation beyond reputeBBray_T1296 has a reputation beyond reputeBBray_T1296 has a reputation beyond reputeBBray_T1296 has a reputation beyond reputeBBray_T1296 has a reputation beyond reputeBBray_T1296 has a reputation beyond reputeBBray_T1296 has a reputation beyond repute
Re: Cube and Cubify to go away
Proprietary anything always throws a red flag in my mind. Pulling stunts like you just said is a sure-fire way to make me never support and actually actively oppose one's organization.
If molecular reactions are deterministic, are all universes identical?
RIP David Shafer: you will be missed
  #18   Spotlight this post!
Unread 02-01-2016, 09:59
samir13k samir13k is offline
AKA: Samir Shaikh
FRC #4329
samir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant future
Send a message via AIM to samir13k Send a message via MSN to samir13k
I doubt that you can bypass the Chip on the Ekocycle, since some of you may have a Cube 2, the trick is:
Install a Cube Cartridge as usual in its slot but feed a bulk roll into the head of the printer.
Once the print had started, hit the stop button and the printer should ask you if you want to confirm that you want to stop the print (the printer should still be printing). At this point, you will want to pull the Cube Filament Cartridge out of the slot so that the IC on the cartridge is no longer touching the contacts on the printer. This will prevent the filament level decreasing on your cartridge. The missing cartridge timeout will not begin as long as the screen stays on the "are you sure?" Screen (paraphrasing, don't know the exact wording on the screen).
The bad, you can see your print progress and its a little extra work. The good, you can use bulk filament.
From what I recall, cube filament is 1.7mm (1.65mm)while the industry standard is 1.75mm
On the cube 2, you can remove the print head cover via the two screws on top. Inside there will be a nut (towards the lower side of the front of the print head, should be facing left when you look at the printer from the front). If you loosen this nut you can adjust the tension on the feed stepper in order to allow for the larger filament.
This is probably a little out of place on this thread, but hopefully it helps someone. I use "JustPLA" and "JustABS" from
Amazon, it seems to be decent, but I wouldn't say it's flawless. My feed has still jammed with these (albeit rarely)
  #19   Spotlight this post!
Unread 02-01-2016, 10:19
Sperkowsky's Avatar
Sperkowsky Sperkowsky is offline
Professional Multitasker
AKA: Samuel Perkowsky
FRC #2869 (Regal Eagles)
Team Role: Leadership
Rookie Year: 2014
Sperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond repute
We had both the cube and the ekocycle printers. Both broke after 1 season. Both were human error imo but that's a story for a different day.
I talked to Avi Reichental(previous ceo of 3d systems) and asked him why they took this approach. He actually said to me "because I'm greedy." I'm happy he stepped. Down from his position and even happier they stopped clouding up the consumer space with these pieces of crap. Although I do thank them for supporting us.
Before anyone doubts how I talked to avi. It was at the inside 3d printing show where I had a press pass allowing me to go to the back conference rooms to find him. I only wish I got what he said on tape bet he would have stepped down sooner.
  #20   Spotlight this post!
Unread 02-01-2016, 13:27
Munchskull's Avatar
Munchskull Munchskull is offline
CAD Designer/ Electrical Consaltant
AKA: Anthony Cardinali
FRC #0997 (Spartan Robotics)
Team Role: CAD
Rookie Year: 2013
Munchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to behold
I guess I am the only one who has had a good experience with the ekocycle then. Only problem has been the filiment pricing.
“In theory, theory and practice are the same. In practice, they are not.” ― Anonymous
Anthony Cardinali
4th year of FRC
Class of 2017
