Re: Index of Robot Code Releases
Here is our java code for team 3944 All Knights.
Our code is for mecanum drive. Here is the link to githubhttps://github.com/AnnaDtest/AllKnights2015.git and separate CD post here: http://www.chiefdelphi.com/forums/sh...d.php?t=140981 Thanks for taking this on! |
Beast Robotics, Team 2202's code for Recycle Rush is available at:
https://github.com/2202Programming/2015 Code is in C++/WPILib. It was the first year we used mecanum drive. The team is also in the process of implementing token commands. Kind of like an interpreter. You provide a table of commands, and the program executes them. In 2015, the team substantially modularized most of the functions which are called by the main process. In 2016, we hope to rewrite the main process to be a command interpreter that will then call each independent module at the appropriate time. Last edited by rich2202 : 07-01-2016 at 06:12. |
In that case, I would recommend getting additional people to help you, particularly if you made the list without planning on it growing to a substantial size. That or, ideally, using a wiki or something in The Blue Alliance instead (for ease of editing, and unity with other information, respectively)
I think the blue alliance would be the ideal place for this sort of thing. There's a pull request that I saw that has inclusion for links to team's github accounts, they might be open to this sort of thing too.
Having a single flat list will get unwieldly very quickly. |
Team 2990 Hotwire: https://github.com/HotwireRobotics/2015FRCRobot
Nothing special. Tried introducing the NavX, but it was still in beta, so we decided not to use it at Worlds. We also implemented stops on our lift and a limit switch on the carriage so that it would know where it was (which "level"). CD post: http://www.chiefdelphi.com/forums/sh...73#post1517773 |
Team 5053: Laker Robotics (Labview & Java) including easy to use Motion Control for Java (well I think it is easy, at least that was the objective).
2015 Labview Code https://github.com/LakerRobotics/FRC2015RobotCode.git
2016 Java Code https://github.com/LakerRobotics/FRC2015Java.git
Thanks for compiling this resource.
Team 1868's code can be found here: https://github.com/team1868/SCcode2015 The CD post can be found here: http://www.chiefdelphi.com/forums/sh....php?p=1517876 |
As suggested by multiple people, I'm doing a couple of things:
Shout-out to Emile Hamwey from 3467 for offering to help review pull requests! I'll see how the load gets, and we can add more people as necessary. Re: GitHub not being the right platform: you're probably correct. We'll do it like this until we see if it's good enough or if we need something else. |
Team 2202, Beast Robotics
Current progress on porting last year's C++ code to Java. https://github.com/2202Programming/JavaTesting |
#10
Mecanum/NavX-MXP Drive System Code (Java):
LED Strip Code (Java): https://github.com/andrew-cadwallade...dressable-LEDs (Re-post of original post by Tythax) |
#11
https://bitbucket.org/987Coders/987_2015_release/src
2015 robot + scripting |
#12
