Go to Post Why assume a full trophy case and spreading the message of FIRST (mentoring rookies) are mutually exclusive? Team 16 supported 6 rookies this season and earned 5 banners - I am equally proud of both. - Meredith Novak [more]
Unread 05-01-2016, 14:52
Greg Needel's Avatar Unsung FIRST Hero
Greg Needel Greg Needel is offline
REVving up for a new season
FRC #2848 (All-sparks)
Greg Needel has a reputation beyond reputeGreg Needel has a reputation beyond reputeGreg Needel has a reputation beyond reputeGreg Needel has a reputation beyond reputeGreg Needel has a reputation beyond reputeGreg Needel has a reputation beyond reputeGreg Needel has a reputation beyond reputeGreg Needel has a reputation beyond reputeGreg Needel has a reputation beyond reputeGreg Needel has a reputation beyond reputeGreg Needel has a reputation beyond repute
REV Robotics 2016 Products
Hey All,
We took a distributed approach to our product announcement this year, rolling them out as products were available. I thought with kickoff just around the corner we would provide you with one central spot to highlight some of the things we have going on this year.
New for 2016
  • SPARK motor controller - The lowest cost FRC legal motor controller at $45 Fully Featured, and built to withstand anything your FRC team can throw at it. Features passive cooling, limit switch inputs, Brake/cost modes, and more.
    Teams were asking for more testing data so, we just released some of our own and team 1718 did also.
  • More Board v2 - A new version of our breakout board for the roboRIO MXP. It has some improved features and layout, including one of the most requested features, a pass through connector (so you can now stack other boards like the NavX). It allows your team to gain easy access to all of the IO inside the roboRIO.
  • Digit MXP Display - multi-use MXP board for interface with the roboRIO. It has four 12 segment displays, which can be used to show any letters or numbers. It also features an analog potentiometer and two momentary buttons. Teams can use the digit to display their battery voltage, select autonomous modes, tune PID variables, or display real time messages. The Digit communicates with the roboRIO using the I2C interface.
  • Analog Pressure sensor - a 5V sensor that can measure pressures up to 200 PSI. It outputs an analog voltage that is proportional to the measured pressure and can plug directly into the roboRIO so you can create smart features on your robot while monitoring pressure & display your real time pressure on your smart dashboard.
  • Smart Robot Servo & Programmer - a configurable metal-geared servo that takes the guesswork out of aligning and adjusting servo based mechanisms. One SRS can be used as a standard angular servo, a custom angular servo, and a continuous rotation servo by simply changing its settings.
  • 15mm Extrusion building system - We built out our line of brackest and building systems for our new smaller extrusion. It has been used heavily in FTC this year by many teams, but also has quite a bit of utility for FRC teams trying to build small, light and strong mechanisms.
  • 1" Extrusion building system - Same base design as last year with some improvements to some of our brackets & linear motion parts. If you need a strong framing system with the ability to infinitely adjust your position, it is a great easy way to build.
    The extrusion is an integral part to building the new AndyMark Rhino Tank drivetrain
As always, we are committed to providing high quality products at prices that every team can afford. SPARK motor controller and our other electronics products are available on Amazon (free shipping & Prime)
and all of our products (except for the SPARK) are also available on AndyMark.
We wish your teams the best of luck this season and look forward to seeing you at events all over the world :-)
Thanks,
Greg
Greg Needel│www.robogreg.com
Co-founder REV Robotics LLC www.REVrobotics.com
2014 FRC World Champions with 254, 469, & 74
Unread 05-01-2016, 16:46
FTC5110 FTC5110 is offline
FTC #5110 (Wingus & Dingus)
FTC5110 is a splendid one to beholdFTC5110 is a splendid one to beholdFTC5110 is a splendid one to beholdFTC5110 is a splendid one to beholdFTC5110 is a splendid one to beholdFTC5110 is a splendid one to behold
Re: REV Robotics 2016 Products
Hey Greg,
Can you confirm the REV Servo spline is the same as Futaba 3F?
We want to use the Actobotics ServoBlock with them.
https://www.servocity.com/html/servo...b___500__.html
VRC7682/7682E/FTC5110 Wingus & Dingus - Mentor
2016 FTC World Championship - Finalists Edison Division (thanks 6137 & 4997)
2016 VEX World Championship - Game Animation 1st, Programming Skills 3rd, Technology Division Amaze Award, Semifinals
2015 FTC World Championship - Semifinals Edison Division (thanks Cougars & ERX)
2015 VEX World Championship - Overall World Innovate Award, Arts Division Think Award
2015 New Zealand VEX Nationals - Winning Alliance Captain + Finalist Alliance Captain(E) + Pgm Skills Champ (48pts) + Think Award
2014 New Zealand VEX Nationals - Finalist Alliance Captain + Programming Skills Champion + Judges Award
2013 FTC World Championship - Finalist Rockwell Collins Innovate Award
2013 VEX World Championship - MS Amaze Award
2013 New Zealand VEX Nationals - MS Excellence + Judges Award
2012 Asia Pacific VEX Championship - MS Design + Innovate Awards
Unread 05-01-2016, 16:51
Originally Posted by FTC5110 View Post
Hey Greg,
Yes, the Futaba 3F is the same as the REV servo. It is generically referred to as the 25T.
Unread 05-01-2016, 17:01
Great thanks for that. Would you consider adding a replacement gearset for them in the future? No idea if we'll end up with damaged units since we haven't used them in competition but we've repaired a fair few HiTec servos over the years.
Unread 05-01-2016, 21:30
We will have to take a look at this. I haven't heard of any teams breaking the gears in the servos (because they are all metal vs the plastic ones of other servos) but if it starts to happen, we will make them available.
Unread 06-01-2016, 15:38
For reference we chewed through HS-645MG's far too often with gear tooth failures but never had any issues with HS-755MG. I guess we'll see what happens this season and I'm pleased to see you'd consider gearsets if needed.
Unread 06-01-2016, 12:43
kiettyyyy's Avatar
kiettyyyy kiettyyyy is offline
FRC #1538 (The Holy Cows)
kiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond repute
Send a message via AIM to kiettyyyy
The Digit MXP looks awfully familiar to what The Holy Cows designed in 2015. If you were to draw inspiration/copy portions of what another FRC team designed and marketed the product for profit, I'm sure giving credit where it's due is appropriate.
-Kiet Chau
2004-2008 - Software Developer/Driver on Team #968
2008-2011 - Software Developer/Coach/Mentor/"Engineer" on Team #968
2011-Present - Mentor & Engineer on Team #1538
www.team1538.com
Unread 06-01-2016, 15:48
You are correct, this was our over site. The Digit was inspired by the great board that the Holy Cows used last season (minus the gyro, and locking connectors). The idea of putting 12 segment displays on the MXP port was and is a good one.
Our implementation is different as we use an I2C LED driver chip to drive the displays to keep the pins on the MXP open and available for the pass through.
We will update our website to reflect this credit.
Unread 06-01-2016, 16:11
kiettyyyy's Avatar
You must be mistaken. We also used the Holtek HT16K33 I2C LED driver. It's just hiding underneath the displays on ours.
-Kiet Chau
www.team1538.com
Unread 06-01-2016, 17:00
This is 100% my mistake. I saw the awesome board the The Holy Cows used in 2015 while at the Shenzhen off-season event this past year (how I missed it at champs when we were alliance partners is beyond me). We reached out a few times to discuss the design but didn't get a response.
We proceeded to design our own with no knowledge of the components of the board (we thought they were pin mapping). We found the HT16K33, as it is a low cost I2C LED driver that quite a few people use including Adafruit, and apparently also the Holy Cows design.
In the rush to release this before kickoff (it just barely made it), circling back with 1538 and giving appropriate credit is something that we did not do and I am deeply sorry for this. It was a mistake that I take full responsibility for.
In light of this we will be making sure to give credit for this board to the people that inspired it, Team 1538 / The Holy Cows and will work with them farther to try to rectify the mistake.
Unread 25-02-2016, 16:15
JPL69's Avatar
JPL69 JPL69 is offline
FRC #3596 (Rocket Robotics)
Rookie Year: 2013
JPL69 is an unknown quantity at this point
Greg,
We are looking to use the Smart Servo with the roboRIO, but do not see any released specification that the roboRIO PWM signals will use the full 500 - 2500usec range that the Servo is rated for. Can you confirm that the Servo was tested to its full capabilities with the roboRIO?
If you do know the PWM range of the roboRIO can you let us know as well.
Thanks.
