Go to Post I think we need to take away your hammer privileges. - Katy [more]
Unread 05-01-2016, 19:30
AWoL's Avatar
AWoL AWoL is offline
Lvl. 225 Dark Code Mage (Java Type)
AKA: Adam Wolnikowski
FRC #0225 (TechFire)
Rookie Year: 2014
AWoL has a reputation beyond reputeAWoL has a reputation beyond reputeAWoL has a reputation beyond reputeAWoL has a reputation beyond reputeAWoL has a reputation beyond reputeAWoL has a reputation beyond reputeAWoL has a reputation beyond reputeAWoL has a reputation beyond reputeAWoL has a reputation beyond reputeAWoL has a reputation beyond reputeAWoL has a reputation beyond repute
TechFire 225 Code Release
I'm sorry that this is so late, I had meant to do it shortly after Ramp Riot, but never got around to it and Colby Skeggs' post collecting code releases inspired me to finally do it. So anyway, here is TechFire's code release.
We programmed our 2015 Robot, Pheonix, in Java and here are some notable parts of the software:
- robot.commands.drivetrain.FireDrive: This is a drivetrain control command that allows our mecanum drive to behave like a true omnidirectional drive for driving purposes. That is, FireDrive makes the robot move in all directions with the same speed, instead of the traditional behavior for mecanum: full speed forwards and 50% strafe. However, with our ever changing strategy we decided to remove FireDrive in the offseason in favor of maximum speed, so it is commented out.
- robot.commands.drivetrain.StableMode: This command uses a sine function to have the drivetrain compensate for the forward and backward motion of our arm as it moves up and down on its circular path. It ended up not being needed in our strategy so it is not tuned to work perfectly.
- robot.JedisProvider: We originally had the Raspberry Pi on Pheonix running a redis server and using the values from that to serve up our custom HTML and node.js dashboard.
- SimpleTableServer: This the custom dashboard implementation that we switched to. It uses UDP packets to communicate the values to the Pi.
- We also have some motion profiling implemented; robot.commands.drivetrain.ProfiledDriveDistance works well and accurately moves the robot a specified number of feet with a maximum acceleration and velocity in either a triangular or trapezoidal motion profile. The other "profiled" commands need work.
Thank you so much for taking interest in our code!
2016 Competition Results (Co-captain, Driver, and Lead Programmer; Junior)
Springside-Chestnut Hill District Event - WINNER / #2 Seed, #1 Seed's First Pick / Gracious Professionalism Award
Westtown District Event - WINNER / #1 Seed / Industrial Design Award
MAR District Championship - WINNER / #1 Seed / Industrial Design Award / Dean's List Finalist Award (Me)
World Championship, Carson Subdivision - QUARTERFINALIST / #3 Seed, #2 Seed's First Pick
Indiana Robotics Invitational - FINALIST / #14 Seed, #2 Seed's Second Pick
