Go to Post I see people show up to a competition with their masterpiece, and proud of it. They are inspired by what they have accomplished. To make it onto the field is a high-it is the culmination of the thousands of hours of dedication compromises and commitment. They feel on top of the world. That's FIRST. - fox46 [more]
Unread 01-06-2016, 03:18 PM
3205patriots 3205patriots is offline
FRC #3205
3205patriots is an unknown quantity at this point
Java Vision Camera cannot be found
My team wrote vision code for last year and are planning on using it for the imminent FRC competition, but a new problem has developed since we used it last year. I have been researching and other people had a similar problem and attributed it to wpilibs; I just want to know if there is anything I can do to solve it.
ERROR Unhandled exception: VisionException [com.ni.vision.VisionException: IMAQdxError: -1074360310: Camera is already in use.] at [com.ni.vision.NIVision._IMAQdxOpenCamera(Native Method), com.ni.vision.NIVision.IMAQdxOpenCamera(NIVision.j ava:24455), org.usfirst.frc.team3205.robot.subsystems.Vision.c ameraInit(Vision.java:72), org.usfirst.frc.team3205.robot.Robot.robotInit(Rob ot.java:59), edu.wpi.first.wpilibj.IterativeRobot.startCompetit ion(IterativeRobot.java:76), edu.wpi.first.wpilibj.RobotBase.main(RobotBase.jav a:234)]
Unread 01-06-2016, 05:26 PM
Fauge7 Fauge7 is offline
Head programmer
FRC #3019 (firebird robotics)
Rookie Year: 2012
Fauge7 is a name known to allFauge7 is a name known to allFauge7 is a name known to allFauge7 is a name known to allFauge7 is a name known to allFauge7 is a name known to all
Re: Java Vision Camera cannot be found
if you run an opencv program on linux and it uses the camera and close the program. then run the same program again you will find that it returns an error, it simply is the fact that none of the programs are run as root, try restarting the roborio and you should be fine.
