Re: SuperScouter For FRC -- A Multiplatform, Extensible Scouting System
Is it open source?
I would be up to do a Mac/Unix port. I don't have/use Windows personally anymore. How are you doing the networking between tablets and server? I understand that Wifi isn't an option at competition. Is it bluetooth? |
I just downloaded the app. I am the scout for our team and we used an app in other years but unfortunately or mentor who created it had to leave so i may be using this one. If so ill give you a big shout out.
At this time, it is not open source. When you are at competition, there are a few ways that you can transport data. 1) You can use the QR Code function. I did not test apple or windows phone versions, but with the android version, there is a tab in the app that says "Send Data." If you go to that tab and after you have saved data, you can transfer the data by selecting QR Code. It will then display a QR code that you can scan using the QR Code scanner on the server application. 2) You could use ethernet. You can set up a router at competition as long as wireless is turned off. You can still use the ethernet portion of it. There are adapters out there that you can use to bring an ethernet port to a device with micro-usb or lightning cables. Though they can be kind of spendy, it is possible. |
For the networking, the only time networking is required is for schema deployment, which as I stated earlier should be finalized before competition (since determining the data to collect is a vital part of any scouting plan). Other than that, networking is not required, but it is enabled for teams that are wishy-washy about those rules. Bluetooth is possible for the future, but will probably not exist on iOS because of the OS's implementation of Bluetooth (non-standard and undocumented). Last edited by jkoritzinsky : 08-01-2016 at 23:11. |
Tables?
I was just wondering if you could create tables using you app?
Re: Tables?
You cannot create tables that will show up on the mobile devices. If you mean outputting tables, the server outputs a zip with csv files that can be imported into any database.
This is pretty awesome. Suggesting it to the scouting team for evaluation.
To make data entry quicker, could there be a data entry method that is a simple count up or count down toggle? This way I only have to tap a + button when someone scores a boulder for example, rather than moving a slider or manually typing it in. |
this is not my wheelhouse. i created schemas got them onto my phone but am unable to send data from my phone back to the computer. tried using the same http as when i sent it to phone . what am i doing wrong??
thanks |
#10
Is the HTTP Server still on? What is the specific error that you get when sending? Have you tried using the QR scanner instead and seeing if that works? |
#11
Got it to upload back to computer. How do I import to excel? Thanks
#12
Select the Export Data from Regional on the home screen. That will download a zip folder with CSV files with your uploaded data in it. Just open that in Excel
#13
when i create a scheme it does not let me save it CTRL+S does not work and both save buttons that i could find in the interface were not working either.
how do i save my scheme or am i missing a step that i must do before i can save? |
#14
What I've found (Jeremy correct me if I'm wrong), if an option within a schema doesn't have an ID, it won't let you save the schema. (This might be nice to have a warning about)
#15
You are correct. I will add that to the documentation that I am currently working on. I'm pretty busy right now with the start of the semester, but hopefully I'll be able to get it out soon.
