Go to Post We should have a 'Steps Taken For FIRST' contest. Everyone wear a pedometer and keep a log of how many miles you walked at the St. Louis Championship. That could be a lot of fun. Do they make pedometers for robot carts? - JaneYoung [more]
  #31   Spotlight this post!
Unread 17-03-2016, 21:18
teslalab2's Avatar
teslalab2 teslalab2 is offline
RogueBotix LLC
VRC #8091
Rookie Year: 2014
teslalab2 will become famous soon enoughteslalab2 will become famous soon enough
Re: Com wire
I used phone wires that I cut in the center and then inverted the connections and soldered it back together. I did try take the last terminator resistor out and the 4 jags didn't care. honestly though I think it would be easier just to get a crimping set...
I need a jaguar development board for reprogramming a jaguars bootloader. if you have one that you want to sell, pm me. thanks
Run you CanJaguars on arduino with ArduRIO, you can also easily control Talons, Victors,Jaguars and Sparks on PWM. https://sourceforge.net/projects/ardurio/
  #32   Spotlight this post!
Unread 24-03-2016, 18:20
juchong's Avatar
juchong juchong is offline
Electrical Engineer
AKA: Juan Chong
FRC #2655 (Flying Platypi)
juchong is a jewel in the roughjuchong is a jewel in the roughjuchong is a jewel in the rough
Re: Com wire
In a pinch, you can take apart a CAT5e cable with stranded inner conductors and use it to daisy-chain your CAN devices. Alternatively, as cheap as the cable is from CTRE, AndyMark, etc. I would highly recommend buying the correct cable instead of making your own.
Alternatively, you could find some green/yellow 22 or 24 AWG wire and twist your own.
Teams I've worked with:My Website: http://www.juanjchong.com/
What I do: Analog Devices iSensor Product Engineer
