#226
Re: FIRST STRONGHOLD Discussion
![]() Now the question (assuming you accept the absurdity of a drone as a computing device) is how much modification do you get to do before a device is no longer COTS? Adding a tether seems like a pretty big mod. Or can you buy a tethered drone? |
#227
Robot rules say the only telecom usable on the robot is the radio. If you were going to do something g like this, it'd have to have all signals transferred through the radio. The drone would also have to be powered by the main battery.
#228
Once the defenses have all been "Weakened" do you still have to go through them to get to the opponents castle? Or can you use the secret passageway?
#229
I don't see any caveats to the secret passage rules that allow it to become an access path once the outer works are weakened.
#230
Uh, no. Check G20, there's no exceptions.
#231
So is G20 implying you can use it to get back to the neutral zone?
#232
OK thank you. That rule seems a little more complicated than it needs to be.
#234
The rule makes the opponents' secret passage useless to be in, but prevents penalties from accidentally driving into their passage when in the courtyard. After all, with limited visibility it is possible especially for driver stations (particularly left of the castle from drivers' perspective) it would be easy to drive in it.
#235
This game definitely makes up for the lack of excitement last year. #bestGameYet
#236
#237
Just to let you guys know, the Portcullis or "Iron Gate" is a clear solid polycarbonate sheet with black lines painted on. So that forces you to lift from the bottom rather than in the middle. Can't wait to play in this game, looks challenging yet fun. ^_^
#238
I think that there is a lot to thing about in terms of strategy and just the design itself, but if you are able to build a multi-tasking bot things will go very well! Also I feel bad for field reset, recycle rush bothered my and that was just totes!
Team 2729 Storm Robotics! |
#239
This has to be the most exciting (and complicated) game I've seen in my time in FRC. You have to really understand the ALL the game rules, or else you're going to wind up in situations you're not prepared for.
