| Thread Tools |
Rating:
Display Modes |
#91
Re: FIRST STRONGHOLD Discussion
I have read this section, along with section 2.2.2.1. I am fairly confident in my first statement, but not the second. I looked through the figures in the manual and none have the defenses repeated.
#92
You should check page 31. A defense can be damaged (please use the correct term so that searches will pull this post up as a result in the future) if two different robots cross it in autonomous.
#93
Section 3.1.3 of the Game Manual has the information you seek.
#94
We had a quick question regarding the towers,
If the tower has been weakened to 0, if a robot shoots an additional Boulder at the tower, and it goes into a goal, does the alliance still gain points? If the tower has been weakened, will the points from the balls still continue? Thanks, and looking forward to this amazing game ![]() |
#95
on the diagram on page 3, section 1.2 (same image is also on Page 8, section 2) , it shows the audience selected items one to the right of the center. On page 100 however (5.5.10.1) it says that it belongs in the center outer works spot. Am i correct in saying that the pictures in question are in error?
#96
The audience selected item goes in slot 3, which is the center defense. Because of the secret passage, the center defense is not in the center of the field. |
#97
Figure 2-1. By center i mean the center of the 5 outer works, or spot 3. In Figure 2.1 it shows the audience selected one in Position 4/2.
#98
Can you damage your own defense by using it to cross into the neutral zone instead of the secret passage, and if so can you find a rule that states this?
#100
How do you know which ones are audience selected? The text does not tell you. If I understand the audience selection process correctly than the same defense should be used on both sides, there is no defense repeated expect for the low bar. |
#101
Figure 2-1 looks to just be a CAD rendering of the field with all the different DEFENSES installed.
#102
You cannot damage (successful crossing twice) a defense by moving from a courtyard into the neutral zone because the definition of crossing (pg. 31) requires you move the opposite direction.
#103
Page 100, 5.5.10.1 says that the audience selects Outer Works pos 3, and in figure 2-4, it shows pos 3 as in the center (of the 5 outer works spots) and in fugure 2-1 the audience selected is in pos 2 and 4, which is incorrect. |
#104
My question is how do they choose, is it a poll or measured in decibels? |
#105
can you damage your own defense if you go from the neutral zone into your own courtyard?
