Go to Post FIRST doesn't end after high school, for some of us, it is only beginning. - David Kelly [more]
Unread 09-01-2016, 15:17
origamitaco origamitaco is offline
FRC #4328
origamitaco is an unknown quantity at this point
SmartDashboard Crash
SmartDashboard crashes immediately when running Driver Station or when starting from Eclipse. Deleted default save, didn't fix anything. Don't know where to find logfile for crash. Running new 2016 FRC update and WPIlib.
Unread 09-01-2016, 15:43
Joe Ross Joe Ross is offline
FRC #0330 (Beachbots)
Rookie Year: 1997
Re: SmartDashboard Crash
Run SmartDashboard from the command-line and post the output.
Code:
java -jar C:\users\<user>\wpilib\tools\smartdashboard.jar
What version of java are you using? Post the output of
Code:
java -version
Unread 09-01-2016, 23:58
FRC #4328
Sorry I should have checked this sooner. I ended up deleting wpilib folder containing smartdashboard.jar and redownloaded the plugins in eclipse. Worked like a charm but I did have to rearrange the dashboard layout. I'll remember this for future reference though, thanks.
Unread 10-01-2016, 14:54
jreneew2's Avatar
jreneew2 jreneew2 is offline
Alumni of Team 2053 Tigertronics
AKA: Drew Williams
FRC #2053 (TigerTronics)
Rookie Year: 2013
jreneew2 has a spectacular aura aboutjreneew2 has a spectacular aura aboutjreneew2 has a spectacular aura about
Hello, I am having the same issue where as soon as you launch the driver station and the smartdashboard loads, it crashes. I have tried reinstalling the c++ toolchain, and the deleting the eclipse plugins and reinstalling them.
Here are the logs from running Joe's suggestions
Java version:
Code:
C:\Users\tigertronics>java -version
java version "1.8.0_25"
Java(TM) SE Runtime Environment (build 1.8.0_25-b18)
Java HotSpot(TM) 64-Bit Server VM (build 25.25-b02, mixed mode)
running smartdashboard from cmd:
Code:
C:\Users\tigertronics>java -jar C:\users\tigertronics\wpilib\tools\smartdashboar
d.jar
No Extension Folder
platform: /Windows/amd64/
Jan 10, 2016 2:55:27 PM java.util.prefs.WindowsPreferences <init>
WARNING: Could not open/create prefs root node Software\JavaSoft\Prefs at root 0
x80000002. Windows RegCreateKeyEx(...) returned error code 5.
NT: connect() to  port 1735 timed out
Host: roboRIO-2053-frc.local
Loading from    C:\Users\tigertronics\SmartDashboard\save.xml
Loading SmartDashboard widgets....
java.lang.reflect.InvocationTargetException
        at java.awt.EventQueue.invokeAndWait(Unknown Source)
        at javax.swing.SwingUtilities.invokeAndWait(Unknown Source)
        at edu.wpi.first.smartdashboard.main.main(main.java:111)
Caused by: java.lang.NoSuchMethodError: org.jfree.ui.RectangleInsets.<init>(DDDD
)V
        at org.jfree.chart.axis.Axis.<clinit>(Axis.java:136)
        at org.jfree.chart.ChartFactory.createXYLineChart(ChartFactory.java:1525
        at edu.wpi.first.smartdashboard.gui.elements.LinePlot.init(LinePlot.java
:36)
        at edu.wpi.first.smartdashboard.gui.DashboardPanel.addElement(DashboardP
anel.java:268)
        at edu.wpi.first.smartdashboard.gui.DashboardPanel.setField(DashboardPan
el.java:327)
        at edu.wpi.first.smartdashboard.gui.DashboardFrame.load(DashboardFrame.j
ava:304)
        at edu.wpi.first.smartdashboard.main$3.run(main.java:124)
        at java.awt.event.InvocationEvent.dispatch(Unknown Source)
        at java.awt.EventQueue.dispatchEventImpl(Unknown Source)
        at java.awt.EventQueue.access$400(Unknown Source)
        at java.awt.EventQueue$3.run(Unknown Source)
        at java.security.AccessController.doPrivileged(Native Method)
        at java.security.ProtectionDomain$1.doIntersectionPrivilege(Unknown Sour
ce)
        at java.awt.EventQueue.dispatchEvent(Unknown Source)
        at java.awt.EventDispatchThread.pumpOneEventForFilters(Unknown Source)
        at java.awt.EventDispatchThread.pumpEventsForFilter(Unknown Source)
        at java.awt.EventDispatchThread.pumpEventsForHierarchy(Unknown Source)
        at java.awt.EventDispatchThread.pumpEvents(Unknown Source)
        at java.awt.EventDispatchThread.run(Unknown Source)
Any suggestions?
Thanks
Unread 10-01-2016, 15:12
jreneew2's Avatar
AKA: Drew Williams
Rookie Year: 2013
Alright, I figured it out. The reason the smartdashboard crashes is because you are using an old dashboard save from last year. To fix this just navigate to:
Code:
C:\Users\"user"\SmartDashboard
and delete save.xml.
Then it should work,. However, I ran into another issue when formatting different values on the smartdashboard. Whenever I try to change a simple text box to a line plot or simple dial, the value disappears and does not show up again until you reboot the dashboard. When it does reappear, it is just in a text box again.
If anyone can reproduce this issue or has suggestions, please respond.
Unread 11-01-2016, 01:34
Rookie Year: 1997
I duplicated the problem and submitted a patch for review.
Unread 16-01-2016, 14:41
fovea1959's Avatar
fovea1959 fovea1959 is offline
Herder of programmers
AKA: Doug Wegscheid
FRC #3620 (The Average Joes)
Rookie Year: 2011
fovea1959 will become famous soon enough
any idea when the patch will come out as part of an update?
Unread 16-01-2016, 16:29
Rookie Year: 1997
It is in yesterday's update.
Unread 09-02-2016, 01:48
nhchen nhchen is offline
FRC #3799
nhchen is an unknown quantity at this point
This may be a silly question, but how do I get the latest update of smart dashboard? I came across this discussion as our team also ran into line plot issue. And firstforge website doesn't seem to be available anymore. I tried teamforge, but couldn't find the installation files. Thanks
Unread 16-02-2016, 20:05
borgerdingj borgerdingj is offline
FRC #5216
borgerdingj is an unknown quantity at this point
Ditto on that nhchen. We're running into the same issue with the lineplot and compass widgets disappearing. And we haven't necessarily found the latest update of smart dashboard.
