Go to Post Archimedes brings all the bots to the yard! - looneylin [more]
Unread 09-01-2016, 17:03
iambluebear iambluebear is offline
FRC #3882
iambluebear is an unknown quantity at this point
Duplicate Defenses?
Besides the low bar, are there going to be duplicates of defenses on the field? There are 8 unique defenses, but can each alliance pick the same ones? For example, if both alliances pick it, will there ever be two of the portcullis, one on each side?
Unread 09-01-2016, 17:06
tindleroot tindleroot is offline
Free Scouting Help to All
AKA: Casey LeeVan
FRC #4272 (Maverick Boiler Robotics)
Rookie Year: 2007
tindleroot has a reputation beyond reputetindleroot has a reputation beyond reputetindleroot has a reputation beyond reputetindleroot has a reputation beyond reputetindleroot has a reputation beyond reputetindleroot has a reputation beyond reputetindleroot has a reputation beyond reputetindleroot has a reputation beyond reputetindleroot has a reputation beyond reputetindleroot has a reputation beyond reputetindleroot has a reputation beyond repute
Re: Duplicate Defenses?
Each of the eight defenses are grouped in pairs, and one of each pair will be on a side of the field each match. The defenses on the red and blue sides are irrelevant to each other (they could all be the same or all different, or anywhere in between) excepting the defense in position 3 that will be determined by the audience, which will always be the same for both sides.
2012-2013: FTC 4601 (student)
2014-2015: FRC 135 (student) - 5 banners in 2 years!
2016-present: FRC 4272 (mentor)
Thanks to all of our alliance partners!
11, 51, 68, 201, 234, 868, 1108, 1241, 1760, 3147, 3301, 3487, 3865, 4269, 4485, 4580, 5188
Unread 09-01-2016, 17:08
MikLast's Avatar
MikLast MikLast is offline
CAO/Drive Coach
AKA: Mikal Dieatrick
FRC #4513 (Circuit Breakers)
Team Role: Leadership
Rookie Year: 2014
MikLast is a splendid one to beholdMikLast is a splendid one to beholdMikLast is a splendid one to beholdMikLast is a splendid one to beholdMikLast is a splendid one to beholdMikLast is a splendid one to behold
doesnt something (either the parts or the position) move every few matches that the audience chooses?
Check out the FRC Discord!
2014: programmer, scout
2015: programmer, admin, drive team
Innovation in control award, WVHS district event
Innovation in control award, CWU district event
finalist, PNW district championship
2016: CAO, Drive team.
Excellence In Engineering awad, WVHS District event
Unread 09-01-2016, 17:32
GaryVoshol's Avatar
Cogito ergo arbitro
Rookie Year: 2000
There will need to be duplicates of each DEFENSE structure.
First, the audience selection would be the same for both sides. (And Mik, it's picked once each ROUND - meaning the number of matches it takes for each team to play once,)
Then the alliances pick the other DEFENSES independently - so there's nothing to prevent them from picking duplicates.
(since 2004)
Unread 09-01-2016, 17:39
AKA: Casey LeeVan
Rookie Year: 2007
Every match, a different set of parts are put up for audience selection, but still in position 3 on the field. For example, in match 1, the audience may decide between defenses in set A. Then in match 2, they select between defenses in set B, and so on. But the audience-selected defenses are always in position 3.
Unread 09-01-2016, 17:42
ATannahill ATannahill is offline
AKA: Alex Tannahill
ATannahill has a reputation beyond reputeATannahill has a reputation beyond reputeATannahill has a reputation beyond reputeATannahill has a reputation beyond reputeATannahill has a reputation beyond reputeATannahill has a reputation beyond reputeATannahill has a reputation beyond reputeATannahill has a reputation beyond reputeATannahill has a reputation beyond reputeATannahill has a reputation beyond reputeATannahill has a reputation beyond repute
Check again, they don't change every match.
Unread 09-01-2016, 20:52
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
Rookie Year: 1998
Oh thank goodness. I missed the round terminology in skimming that and was worried about the effect of voting every single match would have on cycle time.
