Year of pneumatic tires
Hear ye hear ye I declare this will be the year of pneumatic tires. After playing on the feild today in N.H. IMO for the majority of first teams should use pneumatic tires if they are looking for a solution that gives you the most options. As evidence to show it will work watch 1114 go over the bump in 2012.
Re: Year of pneumatic tires
I hope andymark and WCP are ordering all the pneumatic wheels they can after the 2012 shortage
Forecasting is extremely hard. I am sure they did their best. If they guess too short it only costs them money so they don't want to be short either.
1114's ability to easily go over the bump in 2012 was only because they used pneumatic tires. They also used a wedge system that can be seen here: http://www.simbotics.org/files/games...first/2012.jpg
that was what really helped them jump over the bump, and the pneumatic tires were probably just to make landings smoother. |
How easily do the pneumatic tires fit into a tank drive? I personally have never used them and don't know much about them.
You can direct drive them with a hex shaft which is really nice. The versahub from Vex fits into the wheels we're using. The GreenHorns Ri3D team will be using pneumatic tires, and when we finish the drivetrain we'll put out a ton of videos showing it going over the defense's.
Correct me if I'm wrong. |
On point like usual!
#10
Now that AM is back ordered on Pneumatic tires as well, where else can these be sourced?
They're Cheng Shin Tire C-968's. As long as you find 8inch x 2inch mobility scooter wheels I bet they'll work. (not a guarantee) And I'm sure you can always look around at things like Home Depot or the American version of Canadian Tire and drill hub mounting holes in at least until AndyMark gets more. |
#12
Surprisingly, the cost ended up being almost identical including shipping to what it would have been from AM without shipping. And..... they should be here a week sooner. |
#14
Is there a good source for the hubs other than AM? I have seen a lot of rubber tires and tubes or flat-free inserts, but not a lot in the hub department.
Any links to good hubs appreciated (especially if they are cheap and light) -matto- |
#15
Just got a message that our order (placed Sunday) is shipping, but without the tires. Hubs and inner tubes are apparently coming, though.
