Kick the ball.
Is it possible to kick the ball through the secret passage?
Re: Kick the ball.
it may not be as effective as going on the floor and punching the ball, with more power and accurecy
Re: Kick the ball.
G27 states: A ROBOT may not transfer BOULDERS from the NEUTRAL ZONE to the opponent’s SECRET PASSAGE. Violation: TECH FOUL per BOULDER So that rules out kicking a ball through the opposing alliance's secret passage from the neutral zone. I suppose you can kick it backwards, but that would be very counterproductive. |
Re: Kick the ball.
Your not allowed to move the ball through to the opponents Courtyard in any way shape or form without carrying or following the ball into the opponents zone and then backing back into the neutral zone. Just lobbing balls results in tech fouls.
Re: Kick the ball.
Would it be legal to pick up a boulder from midfield and roll it through one of the defenses to your alliance partner for them to pick it up and score it?
Re: Kick the ball.
See G40.
Re: Kick the ball.
G40: A ROBOT may not cause a BOULDER to move from the NEUTRAL ZONE into the opponent’s
COURTYARD unless: A. the ROBOT contacts the BOULDER within OUTER WORKS, and B. the ROBOT completes its CROSSING (i.e. doesn’t completely back out of the OUTER WORKS into the NEUTRAL ZONE) Violation: TECH FOUL per BOULDER Once you move the boulder into the opponent's courtyard, another robot can take control of the boulder, but your robot must both come in contact with the boulder in the outer works, and pass through the defense. So you cant nudge one through, but I see no harm in giving it to another bot as long as your robot went through the defense. Hope this helped ![]() |
Re: Kick the ball.
I at least think the OP was referring to a Human Player kicking the ball through the Embrasure to return it to play instead instead of bowling it.
I see no reason or rule why not, other than bowling might be easier. |
Re: Kick the ball.
The only problem I could think of from kicking the boulders is the ball could pick up and carry over the defenses. If a team finds a member that can kick the boulders in the right way then they won't have to send bots back to move boulders across the defenses.
#10
Re: Kick the ball.
This is actually something my team talked about for a little while today. There don't seem to be any rules prohibiting kicking the boulder as opposed to just rolling it, it just depends on whether you would rather it to go further down the field or be aimed more accurately.
______________ Mackenzie Glaser Robo Lions 1261 |
#11
Re: Kick the ball.
As previously mentioned, I don't see a rule prohibiting it now, but it will probably be disallowed in a Q and A or manual update pretty soon. I don't think that's within the spirit or nature of the game, so I couldn't imagine them wanting to allow it.
#12
Re: Kick the ball.
I don't think it would bounce out with enough control. Foam dodgeballs like the boulders pick up and slow down easy so it should be easy to kick it right so it gets past the defenses and just drops.
#13
Re: Kick the ball.
Re: Kick the ball.
Re: Kick the ball.
The 2016 FIRST Field Tour Video makes reference to how the feeder stations and how they are intended to be used.
One quote from the video is: "It is imperative for your own safety that you don't reach through these openings, even a little bit. The embrasure is a tight fit for the boulders, so your human player will need accurate bowling skills." My interpretation of the quote from the video is that FIRST will not want or allow human players to kick the ball through the openings if there is a possibility that their foot could 'reach through' one of the openings, for safety reasons. TopperBots Team 4230 :: Duluth, MN :: topperbots4230.com Last edited by paulschonfeld : 01-10-2016 at 11:38 AM. Reason: wanted to include link to team website and information |
